DBW Cruise Control Question
Old 12-31-2010, 07:14 AM
usc2001gc's Avatar
Default DBW Cruise Control Question
Does the Electronic Speedometer output from the PCM have to be hooked up for the Cruise control to work? If so, is there anyway to "trick" the pcm?
Old 12-31-2010, 07:32 AM
garys 68's Avatar
Nope, it reads the speed directly from the VSS.
Old 12-31-2010, 10:38 AM
busta9876's Avatar
What IS required:
Stop Lamp Supply Voltage - This wire should be hooked to the same wire that feeds you're brake lights 12v+ when you press on the brake pedal. TAC module looks for brake light bulb resistance, if using LED brake lights, it won't work. This is a light blue wire that goes to the TAC module.
You also MUST have the TCC brake switch signal to the PCM. If this signal is not received by the PCM, cruise will not function. TCC Brake Switch Signal is 12v+ when brakes are NOT pressed, and the switch OPENS when you hit the brakes. This signal wire is at PCM connector C1-Blue: Pin #33; Purple wire.
Old 12-31-2010, 10:45 PM
slick66's Avatar
Thanks.
