2nd Generation fuel pump mounting location?
Old 01-01-2011, 09:26 PM
bronx_peanut's Avatar
Default 2nd Generation fuel pump mounting location?
I have a 1978 trans am that I have a 5.3 swapped into it. My question is I am running a walbro external pump and corvette filter set up. It is currently mounted higher than it should be and it is causing some trouble with fuel delivery . Where is an ideal location to mount an external pump on a 2nd gen firebird? Thanks again!
Old 01-01-2011, 09:43 PM
Cam72aro's Avatar
I have my stock tank sumped with the vette regulator and walbro 255 external pump mounted in front and above the tank. Not sure if yours is wimped though.
Old 01-01-2011, 09:44 PM
Cam72aro's Avatar
I meant sumped.
Old 01-02-2011, 03:26 AM
eroc022's Avatar
My friends stock tank we made a bracket attached to the backside of the gas tank straps then mounted it there. I'm running an in-tank setup from tanksinc works great so far
Old 01-02-2011, 08:18 AM
samdogmx's Avatar
mines in the trunk next to the fuel cell
Old 01-02-2011, 10:05 AM
Jimbo1367's Avatar
I've seen a plate hung verticaly in front of the tank (from drivers to pass) with a inline pump mounted as low as the tank. Surpricingly it was too bad of a eyesore. I'd probably would of gone this route if having a electric pump buzzing didn't bug me so much. I am hoping my over priced Spectra is ALOT quieter than my buds electric pump for his carb 454
Old 01-02-2011, 10:24 AM
Jimbo1367's Avatar
something like this? http://www.camaroperformers.com/cama.../photo_21.html
Old 01-02-2011, 03:45 PM
Thanks everyone for the help! The link helped out a ton!
Old 01-02-2011, 05:30 PM
Cam72aro's Avatar
The walbro 255 is whisper quiet.
Quick Reply: 2nd Generation fuel pump mounting location?
