Stans 1968 camaro LS swap and other upgrades!
Old 02-04-2011, 06:46 PM
  #61
gMAG's Avatar
Originally Posted by Steve68
Gmag got a pic of the timing chain, want to compare the slack to mine, thnaks
Steve, I don't have pic, but if it helps, it had so little slack. As I recall, a finger pressing in the middle, between each sprocket, produced very little deflection/maybe the thickness of the chain itself (3/8"?).
Old 02-04-2011, 06:54 PM
  #62
gMAG's Avatar
Some people like the Lokar or the OEM cable. They seem to fit the bill nicely.
I found that the correct length for LS1/67-69 Camaro was somewhere in between the 36" & 48". Being that there wasn't an 'in between' cable, I cut a 48" OEM cable which cost $26 @ GM PartsDirect.
1) Remove the metal inner cable by cutting off the ferrule at the pedal end, then pulling the metal cable out from the plastic sheath. Save the ferrule & the plastic gas pedal grommet.
2) Using the plastic outer sheath, size up the 'correct' length in the engine compartment. The plastic sheath can then be dremel cut just before the plastic grommet at the firewall (engine bay side) leaving about a 3/8" (or more!) plastic stub sticking out from the grommet. Then, cut the other end of the plastic sheath to accommodate your proper length.
Buy a 3/4" or 1" metal sleeve (Lowes), just large enough to fit over the ends of the plastic throttle sleeve. Slide both ends of the cut plastic throttle sleeve into the metal sleeve. I used just a bit of rubber gasket seal between the plastic sleeve (carefully) inside the metal sleeve to keep it all together.
2) Re-insert the metal cable into the outer plastic sleeve, pulling it through. Mount the sleeve on the engine, and through the firewall. You can shorten the metal cable to the 'correct' length by cutting at the gas pedal end (I used a dremel w/cutting wheel for this, too...makes a CLEAN cut), leaving enough cable to ALLOW FOR PROPER GAS PEDAL TRAVEL. Before you cut the cable, you might plan on leaving enough cable beyond the replaced ferrule so that a knot can be tied after it for extra security.
I redrilled the ferrule so that it could be slid back on to the 'new' end of the cable. Getting the cable back through the ferrule can be a pain! DON'T FORGET to place the plastic gas pedal grommet on there FIRST, BEFORE THE FERRULE. Ask me how I know this.
Then, tighten/squeeze the ferrule with pliers. If the ferrule isn't allowing you to reuse it, you can always just tie a knot in the cable.
A final note...everything didn't line up exactly as planned. I had to tweak the hole in the firewall bec the grommet on the throttle cbl was a bit larger than the hole, and to make the cable line up with the new "CROSSRAM GAS PEDAL ASSY". I believe that a small hole saw bit with drill was req, but I can't remember what size.(3/4"? maybe).
Just an alternative for you.
Old 02-04-2011, 07:29 PM
  #63
bmf5150's Avatar
I appreciate all the advice!!my timing chain had a little slop in it,I would say it was bad!
Old 02-04-2011, 09:49 PM
  #64
tsnow678's Avatar
I am using the Lokar universal cable for the LS. I used a 6 cylinder pedal out of a 69 nova since it was cable actuated versus the lever style the V8's used. If you try to buy a new one they are around $70 since it is the same pedal used on the cross ram Z/28. You can buy the Lokar pedal but it is $150. I got my 6 cylinder pedal for $20 at the local salvage yard. I reinforced it just to be safe. I will post some pics maybe tomorrow of it so you can reference back to it.
As far as I can tell from what I have read, the timing chains on these engines have slack in them. I used a brand new LS2 (improved links) and I had the same amount of slack in mine. All it drives is the cam unlike the old SBC that drove the cam, distributor, and the oil pump. That is why I didnt bother to degree the cam in. I figure with the slack I was wasting my time.
Old 02-04-2011, 11:27 PM
  #65
gMAG's Avatar
I recall reading about the play in the OEM chain and bought the JWIS version because the slack was less. The reasoning was that over time, slack can become greater, causing timing/efficiency problems.
tsnow, thanks for bringing up the 'crossram' pedal.
Presently, Classic Industries has a 20% off sale, if someone wants a new one...normally $49.99-20% part #14318 for 68-69 Camaro.
Old 02-05-2011, 07:36 AM
  #66
Steve68's Avatar
my new one has some play in it, LS2 I'm guessing it's about right, I'm gonna measure,
Good info on the cable , I got a GM cable and a Dremel, yee hah!
Old 02-05-2011, 07:39 AM
  #67
Steve68's Avatar
Thanks for the info!!!! very useful,
Old 02-05-2011, 10:42 AM
  #68
bmf5150's Avatar
I went with a ls2 chain as well!
Old 02-05-2011, 11:06 AM
  #69
bmf5150's Avatar
Found this for a cable based gas pedal,not bad for price!!!
http://www.restorationperformance.co...r-Pedal/Detail
Old 02-05-2011, 11:11 AM
  #70
tsnow678's Avatar
That is the exact pedal I am using.
Old 02-05-2011, 11:55 AM
  #71
2165 Turbo Rail's Avatar
This is a good looking project! I just finished putting together an LQ4 (6 liter LS1 style motor) with a T76 Turbo in my Dad's 69 GTO Judge clone (build thread link is in my signature below)
it looks like you are making pretty good time. It to me and a buddy 3 and a half months working a couple nights a week for about 4 hours a night in the beginning and then about the last month or so we started doing 4-5 nights a week for about 4-5 hours a night
good luck with your project!
Old 02-05-2011, 07:12 PM
  #72
bmf5150's Avatar
Woohoo,motor is in!!!big thanks to jeremy and rich for the help getting it back in!!!got lucky,went in easy with no major problems!
Old 02-05-2011, 07:45 PM
  #73
gMAG's Avatar
And, completed with the front clip ON.
...that feeling you get when a major chunk (literally) of the project comes together. It's a beautiful thing!
Old 02-05-2011, 09:09 PM
  #74
bmf5150's Avatar
long way to go,but feels good!!!
Old 02-05-2011, 11:08 PM
  #75
tsnow678's Avatar
Looks good too!!!
Old 02-07-2011, 01:51 PM
  #76
scatterbrained's Avatar
Default Latching on!
Beautiful car, looks like a great build. I'll be watching this closely as I am about to put an LS1/T56 combo into my 68 Camaro! Keep up the great work guys, lots of us are out here watching with envy!
Scatter'd
Old 02-07-2011, 04:08 PM
  #77
bmf5150's Avatar
Thanks!!this forum has been great!couldn't have done the swap without the other swap post here!!
Old 02-07-2011, 07:23 PM
  #78
Steve68's Avatar
Oh man Now I'm really falling behind, I need some elves!!!!
Old 02-10-2011, 12:02 PM
  #79
bmf5150's Avatar
Well I talked to street and performance today!they say to put the car down on the ground or on jack stand level!with the end of trans facing down set it with the angle finder to 4 to 5 degrees!then shim it back to 2 degrees that way you have some adjustment!!I was trying to figure out the correct way to set it!
Old 02-10-2011, 12:45 PM
  #80
bmf5150's Avatar
i think im going to put my computer under the passenger seat!i talked to street and performance about it and it didnt sound like a big issuse!
Quick Reply: Stans 1968 camaro LS swap and other upgrades!
