Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ? PLEASE HELP.
Old 01-06-2011, 06:06 PM
waid786's Avatar
Default Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ? PLEASE HELP.
I just bought a 5.3L all aluminum L33 motor which I was told came out of 2005 Silverado. It came with engine harness, DBW pedal. It dit not came with the TAC module or TAC module wire harness.
The service number for my computer is 12589463.
Can someone please tell what TAC module I need?
From what I read so far, the 12590008 is only for 2006+ models and seems easy to find.
Does anyone know if 12590008 TAC Module will work if I also use a 2006 DBW pedal with it?
Thanks
Waid
Attached Thumbnails Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-dsc04929.jpg   Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-dsc04931.jpg   Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-dsc04932.jpg
Old 01-06-2011, 07:21 PM
waid786's Avatar
This is the connectors for 2002-2005.
Attached Thumbnails Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-2002-2005-pedal-sensor.png   Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-2002-2005-tac-module-c1.png   Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-2002-2005-tac-module-c2.png   Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-2002-2005-tac-module-c2b.jpg   Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-2003-2008-throttle-body.png
Old 01-06-2011, 07:22 PM
waid786's Avatar
This is the connectors for 2006-2008.
Attached Thumbnails Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-2006-2008-pedal.png   Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-2006-2008-tac-c2.png
Old 01-06-2011, 07:23 PM
waid786's Avatar
This is the throttle body for 2003 and up.
Attached Thumbnails Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-throttle-body-.png   Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ?  PLEASE HELP.-throttle-body-b.png
Quick Reply: Will 2006 TAC module/2006 DBW Pedal work with 2005 PCM ? PLEASE HELP.
