lr4 vs lm7... how do i tell what is what
Old 01-12-2011, 12:24 AM
massen1981's Avatar
Default lr4 vs lm7... how do i tell what is what
how du i tell the drifins betwin a 4,8 lr4 and a 5,3 lm7 motor...
thanks Mads
Old 01-12-2011, 09:51 AM
chevellepowered's Avatar
if the heads are off.. the 5.3 wil have dish pistons..and 4.8 will be flat top.. or take oil pan off and look at crank number.. part number.or measure stroke..
Old 01-12-2011, 10:59 AM
Pocket's Avatar
Newer 5.3's are flat tops, so the best method is to pull the casting number off the crank
Old 11-02-2012, 09:49 AM
Quicklynx's Avatar
Is there any difference between the 4.8 and 5.3 flexplate?
I'm also curious if there is a difference between the 4.8 and LS2 flexplate and if I can swap the LS2 flexplate onto the 4.8? I want to hook up a 4.8 to my 4L65e trans and was hoping I could do it with parts I already have.
Thanks for any help.
Old 11-02-2012, 11:25 AM
the_merv's Avatar
Flex plates are pretty much the same unless its the extended/spaced crank.
Old 11-02-2012, 01:27 PM
Quicklynx's Avatar
Thanks for the help. Glancing at a few pictures it looks like I might need a spacer since I'm using the 4L65e and not the 4L80e.
Anyone any experience with this?
Old 11-02-2012, 02:33 PM
superbean's Avatar
I would think the spacer is only needed if a trans from an older SBC style engine is used. IE, TH350/400/700R4 or older 4L60. If the trans you are using came from behind an LS or Vortec based motor, than a standard flexplate is all you should need.
Old 11-02-2012, 09:38 PM
the_merv's Avatar
A Spacer is needed with an 80 aswell.
Old 11-05-2012, 08:40 AM
Quicklynx's Avatar
Sounds good. Thanks for the help you all. I appreciate it. I'll figure it out later this week. I just wanted to make sure this would, for the most part, be a direct drop in.
I'll be using the LS2 computer but have HPTuners so shouldn't have an issue getting the motor to run smooth.
Quick Reply: lr4 vs lm7... how do i tell what is what
