Dual Fans Running All the Time?????
Both of my fans kick on approximately 10 seconds after my engine starts (hot or cold). I'm running a LS2 with a custom harness that has separate relays for each fan. I have a Vintage Air system, but it is not currently installed.
Seems like I recall reading somewhere on here that an "open" circuit on the AC either sends or causes the computer to detect a high pressure condition / reading (whatever that is) which causes both fans to run at max output? I've search like mad, but I can't find anything on this? Is this true and how to I trick the computer in the meanwhile?
I would appreciate any input from the LS gurus out there... Thanks!
Here is a link to a discussion on the issue. Hope it helps...
https://ls1tech.com/forums/pcm-diagn...ans-issue.html
I am pretty sure the fans have two speeds: low and high. In low, both fans turn at a lower speed because the relays wire them in series, giving them each half the electrical system's power. In high, the relays wire the fans in parallel, giving each one the electrical system's full power.
This may help explain why both fans run at the same time, rather than just one running at a time.
Thanks for replies. I don't understand why the fans would come on when the engine is cold. Not sure about the two speeds, but I can't imagine mine going faster than they are currently. It seems as if the PCM is sending Max power.
The fans are controlled by the PCM. The settings appear to be correct based upon the scanner we checked the system with. Oddly enough we could toggle the fans with the handheld (scanner) as long as the engine wasn't running. Upon start however; we could no longer overide or manually turn them on or off with the scanner. Still scratching my head on this one...
Updated with a new problem...
I determined the fans were running constantly because ECM was programmed to accomodate the factory AC system. My programmer removed these codes / setting and wa la... the fans no longer come on at start up.
The new problem is that they refuse to come on at any temperature now! That old saying about taking one step forward and two steps backwards is proving true... ugh!
Any thoughts or ideas as to why the fans won't turn on now?
If your still able to turn the fans on and off with the engine off, I think its still in the software.
If the fans cannot be commanded on/off with the engine off, I would confirm where your relays are getting their power. What is your relay setup?
LS1Tech Sponsor
Are you still running an LS2 PCM? Is this a 58x or 24x application?
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
I'm running a 2005 E40 ECM/PCM that has been bench programmed for my specific application (vats removed, 2 O2 sensors, etc.)
My engine is an early model 24x reluctor LS2 engine. Appreciate any additional thoughts?
BTW - I don't have Tech 2 and my car is the build stage which makes it difficult to get to a shop, so I don't know if the fans can be toggled manually. I was hoping to avoid this step, but it may be inevitable.
