96 Impala SS Ls1 swap questions..... - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 01-26-2011, 05:47 PM   #1
Default 96 Impala SS Ls1 swap questions.....
Got a 96 Impala SS that the customer wants to swap a Ls1 into. My main questions are...what headers work good for this swap. We have some longtubes for the LT1 that have been nothing but burned plug wires...so a user friendly set would be nice. The biggest concern is the tranny. He has built the 4l60e that is in the car, but Im not sure if the LS1 wiring harness can control the older transmission. Are the plugs the same? Thanks for any help provided!
Chris
Cmarsh is offline   Reply With Quote
Old 01-26-2011, 06:06 PM   #2
aknovaman's Avatar
Some camaro long tubes (with light modification) or stock f-body manifolds will work. Trans connector is same as LS1 pinout as they are both 4L60e. Do not use the bolt at the 2 o-'clock position. If you attempt to drill and tap the block, you will hit water. Chk the Imp SS forum.
aknovaman is offline   Reply With Quote
Old 01-26-2011, 06:17 PM   #3
bigwill1983's Avatar
http://www.brphotrods.com www.hotrodlane.com i went with BRP for the motor mounts and headers street & performance also has a kit also. but for the tranny one of those guys can help you out with that some guys can still use it they just get the pcm programmed to work with and you would also need a flywheel spacer for it to reach the converter. current performance is a good place to get the wiring harness reworked also speartech does good wiring too. stock drive shaft wont work need a custom one.
bigwill1983 is offline   Reply With Quote
Old 01-26-2011, 06:21 PM   #4
gofastwclass's Avatar
You will also need the transmission spacer and appropriate bolts. I have the GM part listed in my build in my sig but there are other places to get them.
gofastwclass is offline   Reply With Quote
Old 07-14-2011, 09:12 PM   #5
sorry to high jack this post , but does any one know what kind of driveshaft upgrade needs to be done ? im currently in the middle of doing one and i was told my shaft is too short ??
HollywoodFL is offline   Reply With Quote
Old 07-17-2011, 09:00 PM   #6
if your using the stock transmission out of it your going to need to get a new drive shaft.the input shaft is going to be like 2 inches short where it wont go all the way in the tranny tail housing.
Old 07-18-2011, 04:53 AM   #7
All of the above is true. I hear that the Pacesetter "truck" longtubes fit pretty well. Only have to ding one primary. You can use the older tranny, just follow what everyone else said. Check out my post under Engine Performance at impalassforum.com
GA95DCMSS is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
LS swap shops or help in Atlanta Ga area Strokedluxury Conversions & Hybrids 0 04-02-2016 09:33 AM
Changing spark plugs on an LS4 Uncle D LS4 Performance 14 08-20-2009 11:55 PM
Bbody tranny swap question... ss.slp.ls1 LT1-LT4 Modifications 4 03-03-2009 04:37 PM
LS1 in a 96 Impala SS kbanks80 Conversions & Hybrids 11 02-19-2007 08:16 AM
Tags
1996, 96, bubble, conversion, harness, imp, impala, kit, ls, ls1, lsx, lt1, motor, mounts, ss, swap, transmission, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
