g-body, truck acc,no power steering
Old 01-27-2011, 10:42 AM
supreme84's Avatar
Default g-body, truck acc,no power steering
Hi, I bought a manual steering box from a s-10 and I want to know how I could keep my 6.0 truck accesories in my 84 cutlass. Is there a way to remove the pump and run the belt an other way. any pictures of a similar set-up would be very appreciated. I dont want to change the whole setup so thanks for your ideas !!
Old 01-27-2011, 11:18 AM
garys 68's Avatar
Simple and stupid. Start at the bottom of the crank going counter clockwise. Up to the alternator, under the water pump, over the tensioner, back to the crank bottom.
I have AC and lowered the alternator for hood clearance, but it works fine.
Old 01-27-2011, 12:53 PM
alitz's Avatar
I bought a bracket from speedway which came with a belt
http://www.speedwaymotors.com/LS1-Vo...isplayId=42493
Old 01-27-2011, 08:35 PM
The stunningman's Avatar
I simply bought a shorter belt.
Old 01-28-2011, 12:31 AM
supreme84's Avatar
thanks a lot stunningman !! that's exactly what i was looking for, could you tell me the lenght or part number if the belt !!! thanks a lot
Old 01-29-2011, 03:45 PM
The belt is 68.5 inches. Part number should be 685K
Old 01-30-2011, 09:42 AM
knievel's Avatar
I cut the bracket off for the power steering and used a different belt
it was the easiest thing to do for what I had to deal with
I'll get the belt size for you later in the day
Quick Reply: g-body, truck acc,no power steering
