LS1 Swap Cant find the pink wires???
Hi guys, i have completed a ls1 swap in my shop, and i cant seem to find all the pink wires, i found 1 pink in the Blue connector 19, i also found the two orange wires that battery,
to my understanding there are more pink ignition wires but i cant find them in the red or blue pcm connectors....
should there be 3 wires that go to ignition? so far i have only found one.
i still cant find them... in the other swaps i usually find all the wires in the bottom part of the fuse box (under fuse box), this wiring has no Fuse box wiring attached to it, or at least i cant seem to find it.
do i need to give power through the fuse box still? or directly from all sensors?
starter signal? maybe thats what im missing.... info on that... the wiring came out of an ls1 based car, which one i have no clue, also all sensors, coils and injectors are HOT, so when i run a test light everything has a current, but nothing wants to work..
