Sikky complete mount packages s13/s14
Complete motor mount kit with all accessories available as a package deal
New Formula D rules do not allow notching or modification of crossmember / subframe.
With the Sikky kit there is no notching or modification of factory crossmember / Subframe.
Competition Legal, direct drop in kit.
Kit Includes:
Aluminum Race Oil Pan V3
•7 quart high capacity design using half inch flanges at block and bell housing allowing for OEM like structural integrity, not like most flimsy aftermarket pans.
•6061 CNC machined flanges and trans flange allowing stock dust shield install
•Baffle and trap doors to prevent oil starvation
•New OEM oil pan gasket
•Custom Oil pickup
Remote mount filter Kit
• 8 AN fittings (2) and stainless braided lines (2)
•Remote oil filter base
•High quality oil filter
•All fittings and hardware
Engine Mounts & Transmission Mounts
•CAD/CAM designed CNC machined solid 6061 T-6 aluminum mounts
•Sikky Green Urethane Bushings that provide true isolation
•High Grade Hardware Kit
•Proper Engine Placement and Axle Alignment
•Lifetime Warranty on engine mounts
Trans Mount
•CAD/CAM designed
•CNC bent Steel mount bracket
•Urethane bushing
•High Grade Hardware kit
•Lifetime Warranty on transmission mount
Driveshaft
•Steel One Piece Driveshaft with high strength U-joints( aluminum upgrade available)
Power Steering line fits like OEM for easy install with high performance line
Features:
•Fits LS1 & LS1 Power steering reservoirs
•Swiveling fitting for optimum fitment
•Maximum durability to heat and racing conditions
•Extreme high pressure line with max pressure of 48,000 PSI for no worries of breakage
•Includes Low pressure power steering return line w/ clamps
Master Cylinder kit. A simple solution for clutch hydraulics on the S13/S14. This bolt on kit will take all the headaches out of bleeding the LSX clutch hydraulics. Everything needed is included
Features:
•CAD/CAM designed CNC billet aluminum adapter plate
•Wilwood 3/4" master cylinder
•All needed stainless braided lines
•Sikky adapter fitting that threads into factory GM slave cylinder without modification
•Bleeder line and custom bracket
•All needed hardware and fittings
Sikky headers allow perfect drop in fitment in S13/S14 240sx with LS1 motor w/T56 (Camaro) transmission using Sikky motor mounts.
•LS1 S13/S14 1 3/4" primaries 3" collector mild steel header
Recommended for Street use ( Less than 500 HP)
other header options available upon request
Plug and Play Wire Harness Service
Send us both upper and lower Nissan Harnesses, and your LS1 harness.
we send back a complete plug and play engine harness
All of this for only $2978.00 own the best LS based engine mount system in the world!
+ shipping
for pix and more info please see our website
www.sikky.com
Kit Includes:
•Custom Oil pickup
Trans Mount
•CAD/CAM designed
•Urethane bushing
Driveshaft
Features:
Features:
+ shipping
www.sikky.com
