which pcm?
which pcm?
i bought a ls6 out of a 05 cts-v and need to know which pcm would be best to use with it? im new to ls thing so wanna make sure i get the right one. its going in a 70 chevy shortwide.
I believe that an '05 OEM V (Serv. #12589462, Hdw. #12589161) ecm has the drivers and will work for either application. They are also found pretty common usage in 2003+ Yukons, Suburbans, and Savanna/Express vans.
Another Savanna/Express ecm, Serv. #12576106, Hdw. #12570558 also has the IAC drivers for a cable throttle.
The very common 12200411 ecm will also work in both applications.
There's a thread on here somewhere about converting dbw harnesses to cable configuration that has all the info you'll need.
