Flywheel Question....
I am swapping a 2000 LS1 into a 95 Z28. I know that the LT1 flywheel will only work if I use a spacer to line up the teeth with the starter. My question is what if I used a flywheel from a 2000 Z28? Any issues bolting up to the older 4l60E tranny?
Thanks
Thanks
The older flywheel will NOT work - the bolt patterns are incorrect.
The LSx flywheel is what you need with the spacer after the flywheel and six longer bolts. The bolt holes will have to be elongated for the torque converter with a die grinder, Dremel or file (it's not far off). There are conversion kits with what you need but if you aren't racing the factory stuff is fine.
I'm pretty much a newb...just to the point of knowing what questions to ask! lol Thanks for the info. I can get a flywheel from a 2000 Z-28. If I get that where can I get the spacer? And what is the correct term for it?
Thanks
Thanks
GMPP sells the spacer and bolts you need but there are other places that have them too. I have a GMPP dealer close to me and when I bought mine there weren't many other options. I think it was around $90 for the adapter and six new longer bolts.
The GM part numbers are 12563532 and you will need six of 12563533. The big online performance houses sell this stuff too, but I got it cheaper through my GMPP connection. There are other companies that sell the same parts form aftermarket manufacturers but I don't have any info on them.
You do realize the LSx PCM can't control the 1995 torque converter lockup and shifting, right? The 1996 and newer transmissions are Pulse Width Modulated and the older ones are not. This and the spacer info are covered in my Thunderbird build topic in my signature.
You said that twice.
That would be cool if he could. The things I read in multiple places from trans shops, etc. when I was searching said you can't and 96 was the magic year. I know spotting one is as simple as removing the converter and looking for PWM on the front pump. I've been wrong before, so my feelings won't be hurt if I'm wrong again.
I included a pic of the wiring diagram to take away any doubt you have whether it will work or not.
