LT1 to LS1 swap. 97 t/a
Old 02-14-2011, 12:55 PM
klutch-'s Avatar
Default LT1 to LS1 swap. 97 t/a
To-do list/parts list:
LS1 motor
pace setter headers
LS1 k-member=
http://www.spohn.net/shop/1998-2002-...s-Accessories/
LS1 steering shaft=
http://cgi.ebay.com/ebaymotors/ws/eB...d=160542958436
LS1 rack and pinion?=
http://www.oreillyauto.com/site/c/se...ird&vi=1382475
00+ Corvette fuel filter=
http://www.oreillyauto.com/site/c/se...tte&vi=1371293
braided line from fuel filter to fuel rail
Re-wire LT1 harness to LS1 motor.
Anything im missing??? this is just the basics that i KNOW i need...
Old 02-14-2011, 02:52 PM
flame's Avatar
Check out the link in my sig for my swap details. Not sure what trans you have either?
Old 02-14-2011, 03:07 PM
klutch-'s Avatar
same trans, automatic 4L60E
Edit: i have ur link saved to my favorites. forgot about the flexplate
Old 02-14-2011, 05:30 PM
the_merv's Avatar
Check into the Auto Crossmember.. Where you getting the LS Harness & PCM?
The LT1 Engine Harness or PCM will not work.
Old 02-14-2011, 08:56 PM
klutch-'s Avatar
Thought I could wire the ls1 motor to the lt1 pcm?
Old 02-14-2011, 10:38 PM
the_merv's Avatar
Negative..start hunting for a LS1 Fbody Harness & PCM.
Old 02-14-2011, 11:07 PM
klutch-'s Avatar
I have a ls1 harness pcm and tcm from a trailblazer as 2008. Will that work?
Old 02-14-2011, 11:14 PM
fergymoto's Avatar
I have a 2001 LS1 harness that is wired for plug and play in my '97 Trans Am. I may be putting it back to stock, and I will be selling the harness if I do. It is also wired for both A4 and M6 transmissions, and I have run it with both. It's pretty bad ***
Old 02-14-2011, 11:17 PM
klutch-'s Avatar
Price? Availability?
Old 02-14-2011, 11:41 PM
klutch-'s Avatar
The wiring harness write up u have is explaining how to do what? Cuz I thought it was how to wire a ls motor to a lt harness. Is it to wire a ls hasness to a lt pcm?
Old 02-15-2011, 09:02 AM
the_merv's Avatar
It's to wire a LS Engine Harness into the LT1 Chassis Harness..you will need a LS Engine Harness & PCM to run the LS Engine.
The 2008 setup will partially work. The Harness can be re-worked, but you will need the PCM from a LS1 F-body.
Old 02-15-2011, 12:13 PM
klutch-'s Avatar
ahh i gotcha! that way the gauges in the car will work and stuff? (i must have mis read that)
well damn so im gonna need a LS1 F-body pcm and wiring harness?
also i traded the 6.0 (out of the 08 trail blazer SS) for the LS1, will the front accessories from the 6.0 bolt to the LS1? will i have any clearance issues with the 6.0 accessories since it came out a trail blazer?
thanks for all the info by the way... i wouldnt do this swap with out all of yalls help!!
Edit: would this work for the PCM? http://cgi.ebay.com/ebaymotors/Camar...Q5fAccessories
Old 02-15-2011, 12:32 PM
klutch-'s Avatar
also i have another question. the guy im swapping my 6.0 for his LS1, is he gonna be able to use his LS1 harness and PCM or will he need my 6.0 harness and pcm?
Quick Reply: LT1 to LS1 swap. 97 t/a
