CPS or MAF connector?
For a truck harness the CMP and MAF connectors should not be the same. Trucks use a 5 wire MAF where Fbodys used a 3 wire that used the same body as the CMP, the CAM also fits. MAP uses a similar connector of the same series but the alignment tab doesnt fit anything but MAP sensors
MAF is PNK, BLK, YEL
CMP is LT GRN, YEL, DK BLU
CAM is RED, PNK, BRN
MAP is LT GRN, GRY, BLK or ORG
