Using Stock F-Body Fuel Sending Unit: Fuel Line Configuration Question
Old 02-24-2011, 12:47 AM
jacobm99's Avatar
Default Using Stock F-Body Fuel Sending Unit: Fuel Line Configuration Question
I am running a stock F-body fuel sending unit (with built in regulator) and am wondering how to configure my feed and return lines. I know that many are running the Corvette FPR/filter set up which has both the feed and return running directly to the FPR/filter, but since the F-body sending unit has the built in regulator, how should I run my fuel lines? Would I just "T" the return line in the the feed line and put the filter in between the "T" and the fuel rail?
Old 02-25-2011, 11:13 AM
jacobm99's Avatar
To the top.
Old 02-25-2011, 12:45 PM
bmf5150's Avatar
Have the dual lines is a better way to go from what I hear,just run two lines from tank to fuel rail,put a in line fuel filter in the feed line somewhere!the older dual in out fuel rails have built in fuel regulator!
Old 02-26-2011, 12:32 AM
jacobm99's Avatar
Thanks for the reply. Since I'm using the stock sending unit (with the built in regulator), wouldn't I need to use the feed-only style fuel rail, and not the older feed/return style fuel rail, since it also has a regulator on it?
Also, assuming I use the feed-only fuel rail, how would I configure the return line given that i'm using the stock sending unit?
Old 02-26-2011, 09:57 PM
Rick Speed's Avatar
If you have an LS1 fuel sending unit you will need to put a Y in the line back by the pump and use a returnless fuel rail (LS1 f-body's had a block that 3 lines went into)
Quick Reply: Using Stock F-Body Fuel Sending Unit: Fuel Line Configuration Question
