Missing Parts. Should I go Carb or stick with FI ?
I have an LS1 in a '55 Buick. I don't have a harness, PCM or MAF.
It seems like the PSI harness is a good mix of value and quality. Do I just need a MAF and PCM? Anything else big I'm not thinking of?
At that point, would it be significanty easier or cheaper to go the Edelbrock / MSD carb route?
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
A used harness can be found as well if you do some searching then have it modified. Or spend the money on one ready to go.
If you go carb you'll need a intake, carb, fuel pump, and ignition system. It adds up pretty quick.
You don't have to have a MAF you could tune for Speed Density and leave it out. And you can get PCM for cheap on fleabay etc...
I need a fuel system either way, so that's a wash. The intake carb and MSD is about $1000.00. The harness is like $500, so it seems like even getting a PCM and tuned, it might even be cheaper. I'd rather stick with the FI even if it was a little more.
LS1Tech Sponsor
You should be able to pick up an f-body maf for $75 bucks at a yard.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
