What engine do I have 4.8 or 5.3
Old 03-20-2011, 05:44 PM
mlevario99's Avatar
Exclamation What engine do I have 4.8 or 5.3
I got an engine/tranny combo from a friend, he got the engine/tranny from a wreck truck, I dont have the vin number. I am trying to find out what what size engine I have, a 4.8 or 5.3. The engine came from a 2000 Silverado. The engine block has this number on it 12551358 and in the side of thge block it has a 4.8/5.3 stamp on it. How do I know what engine size I have, I research the 125513548 casting number, but it just tells me that I could be a 4.38 or 5.3.
Thanks
Old 03-20-2011, 05:58 PM
cutlass_455's Avatar
Whats the casting # on the heads?? Should be a 3 digit #.
Old 03-20-2011, 07:24 PM
mlevario99's Avatar
the casting number on the heads is 862.
Thanks for your help
Old 03-20-2011, 08:53 PM
71ANTICARB's Avatar
Those heads came on both. The only ways I know personally is that the 4.8l has flat top pistons and has a different crank.
Old 03-20-2011, 09:01 PM
71ANTICARB's Avatar
Just found this look at the last post.
https://ls1tech.com/forums/conversio...ification.html
Old 03-20-2011, 09:27 PM
trav-tech's Avatar
Pull a spark pug out and shine a flash light in the hole turn the crank till you can see the piston top if it has a dish its a 5.3L if its flat top its a 4.8L
Old 03-20-2011, 09:32 PM
firstgenguy's Avatar
anyone have pictures of the two different pistons? I just pulled my heads.
Old 03-20-2011, 09:40 PM
Bo185's Avatar
You will know the 4.8l will be completely flat and the 5.3L will have a little dish in it.
5.3L pistons
Old 03-20-2011, 09:51 PM
Bo185 I can't see your pic but here is what I have. It's a 2001 block.
Old 03-20-2011, 10:18 PM
eviltwin_1987's Avatar
That's a 5.3
Old 03-20-2011, 10:25 PM
deuce4935's Avatar
^That would be a dished piston from a 5.3 or LQ4, LQ9 and 4.8's had flat tops.
yeah that what I think confusses some people cause there is not much of a "dish".
Old 06-03-2011, 10:28 AM
mlevario99's Avatar
The pistons have the dish so it is a 5.3. I have another question, the following picture shows the flywheel, my question is, do I need to replace it, or I can still use it, two of the three holes are a bit rough, is that normal. Thanks
Old 06-03-2011, 10:34 AM
ShortChevy's Avatar
I would replace that
Old 06-04-2011, 12:49 AM
SSjon's Avatar
It looks like someone cut them out for some sorta conversion to the older style torque converter
Old 06-04-2011, 03:11 PM
Chris10an's Avatar
OK is the 4,8 and 5,3 piston the same hight, so we can use the 4,8 piston to rise the comp on a 5,3L?
Old 06-04-2011, 06:15 PM
Bilster's Avatar
That's correct. The two pistons share the same compression height.It's a fairly popular swap.
Old 06-06-2011, 08:43 AM
mlevario99's Avatar
ok, I am going to replace it. Are the flywheels the same for all 5.3, I believe the truck that this engine came from is a 2000 chevy silverado 2wd.
Bilster, what are the advantages of swaping the pistons form a 4.8 into a 5.3 engine.
Thanks for all your help.
Old 06-06-2011, 07:36 PM
ls1okie's Avatar
Flywheel differs from the 4L60E to the 4l80E. The difference being the flywheel for the 80 will have the spacer for the converter. Advantage to piston swap is you will have a higher compresion 5.3., will only be around 15 hp at the flywheel.
Quick Reply: What engine do I have 4.8 or 5.3
