04 LQ4 to th350
Old 03-28-2011, 03:01 AM
softballnrd27's Avatar
Default 04 LQ4 to th350
I want to make sure I have this right:
2004 LQ4 converting to DBC(not sure what trans was behind it, I forgot to ask) I am posting a pic so that maybe it will help with what I need to know:
I need to adapt my th350 to the 6.0 If it did in fact come with a 4l80e then I should be good as far as spacer and bolts correct? If not then I need to get the spacer and bolts correct? Then I need the flat flexplate and drill holes for the th350 TC? When I go to mark the holes in order to drill new ones, does it matter where on the flexpalte they are drilled? Should there be a certain distance from the factory holes?
For the VSS will this one work with the stock DBC computer? I am going to run Autometer procomp gauges and this is the recommended one for GM.
http://www.summitracing.com/parts/ATM-5291/
