ls to old style manual trans...flywheel?
Old 04-02-2011, 08:54 AM
bad67ls's Avatar
Question ls to old style manual trans...flywheel?
anyone make a flywheel for this swap besides mcleod? ive browsed around a bit but havnt seen anything listed. $430 seems a bit steep...
Old 04-02-2011, 10:19 AM
garys 68's Avatar
Sach 1050.
See my build, I used a 10 spline clutch but you can use a 26 spline 11" clutch too.
https://ls1tech.com/forums/conversio...442-build.html
Old 04-02-2011, 11:53 AM
jetback73nova's Avatar
I have the mcleod on my nova and as far as I know its is the only one that will work correctly. the crank flange on all LS motors is 0.40 inches closer to the block than on the SBC although the bellhousing mounting is the same (there are some early truck engines I believe that have a longer flange but you would have to find one) .the mcleod flywheel has an extra 0.40 inches of thickness to make this up, you could use a stock LS flywheel but the clutch would be 0.40 inches farther out on the trany input shaft and the mechanical linkage if you plan to use it would be difficult to set up. I have heard that you cant just space the the thinner flywheel out ether because the starter will not fully engage the flyweel. there is a fare amount of info about this, search for the car craft build on google.
Old 04-02-2011, 06:12 PM
garys 68's Avatar
Actually on my Richmond 6 speed/LQ9, I used a 621 style bellhousing and LS1 flywheel/clutch. The input shaft engaged fully into the LS7 pilot bushing and the 26 spline clutch was about 95%engaged on the input shaft splines.
The Sachs 1050 flywheel is about 0.4" thicker (and heavier) and is made to engage a 10 spline old style trans to an 05 6.0 truck motor (3500, manual trans).
I used the sachs since it was drilled for the old school 11" clutch that could be used with a 10 spline muncie disk.
Old 04-02-2011, 07:17 PM
bad67ls's Avatar
so wait, your telling me the sachs flywheel will do the same thing the mcleod does for 60 bucks as opposed to 430?!
seriously?!
Old 04-02-2011, 09:25 PM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
seriously?!
First of all, tell us what trans you are using and what the input shaft spline count is.
Andrew
Old 04-03-2011, 09:07 AM
Smokeshow_2006's Avatar
I was under the impression that if you use the flywheel from a 2006 4.8, and an ls7 pilot, you can mount any sbc manual transmission
Old 04-03-2011, 10:21 AM
garys 68's Avatar
Sachs NFW1050 used on silverado (05 3500 manual trans, among others), LS7 pilot bearing, and an 11" BBC clutch (68 for 10 spline, 73+ for 26 spline), 621 bell housing, an adjustable pivot ball, and a 1 1/4" long throwout bearing.
Should allow bolting a TKO, 3550, Richmond, Mucie, T-10, Saginaw, etc to a 01+ LS, LQ, etc.
Get the flywheel and clutch bolts for an 05 3500, manual trans from the dealer.
You need to remove the alignment pins on the flywheel and enlarge 3 holes on the clutch pressure plate.
Old 04-03-2011, 03:52 PM
Gray86hatch's Avatar
Yup used the sacks and a 621 bell with a TKO works perfect.
I think it was $70 out the door. I also had it machined out of the box was not usable in my opinion.
Tim
Old 04-03-2011, 08:14 PM
garys 68's Avatar
BTW, kit form of the above parts with what looks like the Keisler 621 "LS" bellhousing.
http://paceperformance.com/i-5146180...rsion-kit.html
Old 04-03-2011, 11:58 PM
bad67ls's Avatar
richmond 4+1 with a lakewood bell. input spline shouldnt matter, as that only dictates the disc,but its 26 spline.
Old 04-04-2011, 12:04 AM
If you have a 26 spline input nothing special is required. You can use any LS1/6 or LS2/7 clutch that you want. I'm using an LS7 clutch with a Richmond 6spd. Look in my build thread for details. Link in sig.
Andrew
Old 04-04-2011, 06:39 AM
garys 68's Avatar
Wahat he said. The only advantages to that sachs flywheel is that the clutch discs splines wont overlap the the input shaft tapered front.
You'll also need a longer throwout bearing for correct fork geometry with an LS1/2/7 flywheel..
Andrew
Old 04-04-2011, 12:17 PM
bad67ls's Avatar
so is the scahs set up for a standard 11" clutch and pressure plate? I have a brand new ram powergrip setup I plan on using...
Old 04-04-2011, 01:42 PM
garys 68's Avatar
yep, if your clutch fits an ealy 70 big block chevelle, corvette, etc, it should bolt up.
Old 04-04-2011, 04:37 PM
My centerforce 11" bolted right up no issues
It was on the big block prior
Tim
Old 04-04-2011, 05:46 PM
bad67ls's Avatar
you guys are life savers...i was ready to cough up 430 for the mcleod piece. thanks for the info!
Old 04-19-2011, 01:55 PM
pairof69s's Avatar
any updates Bad67ls...? looking at doing the same setup, what are you guys doing about the starter
Old 04-19-2011, 04:59 PM
pairof69s's Avatar
Tim
sorry just jumpin on the thread, what did ya have to machine on the flywheel..?
Old 04-19-2011, 06:00 PM
The friction surface was not flat or very nice to look at. Had it cut just to ensure no problems
Tim
Quick Reply: ls to old style manual trans...flywheel?
