5.3 Alt / PS Bracket & Tensioner P/N's
Old 04-05-2011, 05:29 PM
August's Avatar
Question 5.3 Alt / PS Bracket & Tensioner P/N's
If anyone can help me here with some part numbers I'd be very grateful. I purchased a 5.3 LM7 crate motor to drop into a CJ7. It has the waterpump and harmonic balancer but I need the serpentine belt set-up. If someone has the GM part numbers for the needed or other suggestions this will be very cool. I have found several set-ups for the F-Body and C5 but would need to change out the water pump and H Balancer I think. The tall truck set-up will be fine in a Jeep. Thanks for any help!
Old 04-05-2011, 07:13 PM
deuce4935's Avatar
12554522 is the GM bracket pt#, and Dorman 419-112 is the tensioner.
Old 04-05-2011, 07:15 PM
garys 68's Avatar
Shop around here, ebay, or craigslist for a truck bracket. They're really cheap. I have a spare bracket with PS pump, but shipping would probably be more than you getting a used one locally.
Old 04-05-2011, 07:34 PM
August's Avatar
Thanks ... does this bracket mount the PS down low? Is the PS unit have to be a detached resovoir?
Thanks again
Old 04-06-2011, 07:39 AM
46Coupe's Avatar
I have some 5.3 brackets that have less than 200 miles on them. PM me for details, I'm sure we can work something out.
Old 04-06-2011, 03:53 PM
deuce4935's Avatar
The bracket mounts the ps pump down low and the resevoir attaches directly to the pump.
Quick Reply: 5.3 Alt / PS Bracket & Tensioner P/N's
