82 Fox Body 5.3 swap
Old 04-07-2011, 09:55 PM
FakeSnake's Avatar
Default 82 Fox Body 5.3 swap
Here is my fox I picked up to do a 5.3L/TH400 swap. The build wont start until I get back in the states, from what i was told the car has a Dana rearend and is already pretty much stripped out for a track car. I know it needs a bunch of work since it is pretty rough but the car was free. Can anyone chime in on what type of rear end is in this and will it be ideal for drag racing?
Free Parts (my father owns a salvage yard in south carolina so the big ticket items and odds and ends that nickle and dime ya will be free )
5.3L from 01 Silverado
TH400
Purchased Parts as of now
AJE K member
AJE TH400 Crossmember
AJE LS motor Mounts
Dynatech LS Swap headers
Misc AN fittings and hose
Edelbrock Victor Jr.
MSD 6010
AutoMeter Wideband
Summit Racing Fuel Pump
Fuel Pressure regulator
Parts needed (all i can think of right now...)
Holley 750 DP
Slicks
Shifter and cable
Old 04-08-2011, 01:18 AM
itsslow98's Avatar
Looks like all stock suspension that will have to be addressed, axle tubes and torque boxes need to be welded up, subframe connectors, you have a ton of work ahead of you. Might consider finding a roller thats been setup already for 1500-2k itll be well worth the money.
I paid 2k for mine(1400 after i sold parts i didnt need it came with. that was for a 93 coupe no rust at all, 4.10s, weld draglites with good slicks and skinnies, comp eng drag shocks, tubular kmember, trickflow girdle, ds safety loop, decent interior. i have a build thread on it.
Old 04-08-2011, 04:09 AM
RATBOX's Avatar
Looks like a Dana 44, seems silly considering the over abundance of 8.8's.
Old 04-08-2011, 07:17 AM
johnyrrr's Avatar
If dad owns a junkyard can you put in a 6.0? I mean if all you are doing is racing the thing get the bigger cube motor im thinking. So what if it needs work it was a free car, you obviously know it needs work enjoy it. Love the florescent green "Cobra Stang" on the back of the car from the early 90's
Old 04-08-2011, 07:57 AM
FakeSnake's Avatar
Well, my first choice was the 6.0L but he only has a few of those. He has an abundance of 5.3's so thats what im getting right now, if it blows then ill just get another one.
Old 04-08-2011, 07:07 PM
trav-tech's Avatar
not to mention the fact that the 8.8 is way stronger than a d44
Old 04-16-2011, 09:48 AM
DisturbedTA's Avatar
since that is a 82 it had the 7.5 in it so the previous owner didn't think bout the 8.8 yet
Old 04-16-2011, 10:22 AM
FakeSnake's Avatar
just a little update, this build has taken a major detour in direction....ill give ya a little hint, i just got off the phone with rob at modular turbo
I spend a bunch of money and only get a couple pictures of boxes.... ugh
it sucks being deployed....
1600$ box of parts and all i get was a free hat
boost gauge
AEM injector driver
HP Tuners Pro
MSD 2-step
MT Slicks
waiting on the turbo now, all the vbands and hoses
Old 08-06-2011, 03:42 PM
FakeSnake's Avatar
Default build progress update (pic heavy)
here are some build pics for you guys... found a 4 cyl. coupe for 400$ in pretty good condition so i wouldnt have to use that piece of junk i was originally going to use...
Old 08-06-2011, 03:53 PM
FakeSnake's Avatar
gonna need a cowl...
Old 08-06-2011, 04:16 PM
FakeSnake's Avatar
some more i found..
Old 08-06-2011, 04:19 PM
Dride76's Avatar
Turtle
Old 08-07-2011, 02:40 AM
LSjim's Avatar
nice the notchback looks alot better then the hatch
Old 08-09-2011, 02:47 PM
RATBOX's Avatar
Ya, good change in cars.
Old 08-09-2011, 10:25 PM
RS_SS69's Avatar
Looks like a good start, your 4cyl notch looks exactly like the one I just got down to the colors. Good luck with the build.
Old 08-15-2011, 12:17 AM
Dride76's Avatar
Coming together quick! Need to snap some new pics!
Old 08-18-2011, 08:31 AM
lxwithlaundry's Avatar
kool build so far.. I'm pretty much doing the same thing.. picked up a 89 notch and a 2000 5.3 I'm on a tighter budget so im trying to make alot of my parts and the last thing i'll do is get the 76mm turbo.. I'll tag along on your build to help mine along.. so update
Old 08-18-2011, 04:19 PM
have you thought any about changing the location of the altenator? all Im going to be running is the alternator and water pump off the crank and would like to mount it low so im trying to figure out what i'm going to do about that..
Old 08-23-2011, 02:20 PM
FakeSnake's Avatar
updated pics
Old 08-23-2011, 02:31 PM
FakeSnake's Avatar
gotta run it up there since im doing a truck manifold build... i need a cowl hood anyways to fit the throttle body and carb hat so ill just get a cowl big enough to squeeze the alternator under....
Quick Reply: 82 Fox Body 5.3 swap
