LSX In 91 C4 Corvette My Swap
Old 04-08-2011, 09:14 AM
LSCha0s's Avatar
Default LSX LS1 In 91 C4 Corvette My Swap
Here are the specs.
built/forged 5.7 347 iron block with 241 heads
MS3 cam
237/242, .603"/.609", 113 LSA
LS6 Intake
Wiring harness and PCM from a 99 Z28 tuned for the set up.
I picked up a few more things
Took a 3hr drive but it was worth it.
OEM exhaust and oil pan from a 98 vette. I'm not sure if the oil pan will work but it's worth a shot.
the transmission and a 3000 stall.
Racetronix 255 pump kit and Speehound LS1 conversion mounts.
I cleaned this thing with a wheel brush and tooth brush.What I couldn't reach with those I used a screw driver with a rag.I painted the valve covers coil brackets and fuel rail red to give it some spice. Now it's ready to drop in.
Disregard the ugly truck pan its just there to keep stuff out.
4L60E to 700R4 tail shaft adapter
My A/C high mount bracket came in.
A Sanden 508 type A/C compressor must be used.
Old 04-08-2011, 09:16 AM
LSCha0s's Avatar
The F-body wiring harness is designed to put the PCM in the pass side.I need to mount mine on the drivers side on top of the battery. My plan is to take the harness apart sensor by sensor following the wires to the PCM then labeling the pin location. All the wires on the drivers side are going to be perfect. The passengers side will be too short and need to be extended.. In the processes of dis-assembly I will omit any sensor or wire I will not need. I will also hunt down the 12V commons.
The grounds I will be leaving alone so far they will ground in their original locations on the block.
Old 04-08-2011, 09:19 AM
LSCha0s's Avatar
This is an on going parts list. I will edit as I go along.
Engine, Ecu and wiring $1300
Transmission and converter $1750
Racetronix 255 Fuel pump kit $120
Speehound motor mounts $100
Advanced Adapters 4L60E to 700R4 tail shaft adapter $214
A/C compressor high mount adapter $150
Corvette power steering pump,bracket and pulley $140
Corvettte alternator $100
Powerbond balancer $145
98 Corvette Batwing oil pan and C5 manifolds $50
Oil pan gasket $50
Starter from fleabay $56
Balancer bolt $14 gm
Hoses, and fuse block $80.00
TB cable $50
Tuning $100
Two O2 sensors $120
wirring and terminals $60
Transmission cooler and lines $220
Fuel lines and fittings $70
Radom Tech Cat cons $200
Dual spring kit $300
I might need to get a couple of Dakota Digital boxes
A/C lines and Compressor
Spent $5389.00 and some of this stuff is optional.. for example you dont have to spend $550 on a converter
So far I have made $2945 to offset the cost from sales of my old stuff. I still have a few parts lying around.
Old 04-08-2011, 09:20 AM
LSCha0s's Avatar
I have been working on the harness. I need to order some wire and terminals. Looks like I will be adding length to the pass side. it's all routed and mocked up now. The Camaro harness really only had two connectors I did not need. The AIR and EGR.
Now that I have the PCM connectors off I need to sort through whats left. I have identified the 12V switched wires and plan on hooking them some where fused. The ignition and coil wired share a common 12v wire. I believe I will hook these up to inj1 and inj2 in the fuse panel.
Here is whats left.
Red Connector
9 DK/GRN FUEL PUMP RELAY CONTROL = FP
10 WHT ENG SPEED (TACH) = goes to Tach
13 CRUISE ENABLE= not needed
17 DRK GRN/WHT A/C REQUEST SIGNAL = not sure
30 VDT FUEL ENABLE = VATTS
33 DK BLUE ENG COOLING FAN RELAY 2&3 CONTROL = to cooling fan relay 2
34 EVAP PURGE VALVE CONTROL= not needed
36 AIR PUMP RELAY CONTROL= not needed
37 DK GRN CRUISE CONTROL INHIBIT= not needed
43 DK GRN/WHT A/C CLUTCH RELAY RELAY CONTROL=not sure
45 WHT EVAP CANISTER VENT VALVE CONTROL= not needed
46 BRN/WHT MALFUNCTION INDICATOR LIGHT CONTROL= MIL ck eng light
50 DK GRN/WHT VEHICLE SPEED OUTPUT CIRCUIT= to speedo
17 DRK GRN/WHT A/C REQUEST SIGNAL=not sure
53 GRA/BLK SPARK RETARD CONTROL=not sure
54 PPL FUEL LEVEL SENSOR SIGNAL= not needed
64 DK GREEN FUEL TANK PRESSURE SENSOR= not needed
Blue Connector
19 PNK IGNITION POS VOLT= to switched 12v
20 ORG BAT POS VOLT=to 12v
23 GRA FUEL SENSOR /FUEL TANK SENDER GROUND== not needed
33 PPL TCC BRAKE SWITCH= to brake switch
34 ORG/BLK PNP WITCH= to park neutral safety switch
42 COOLING FAN RELAY CONTROL= Cooling fan relay
Feel free to correct me or help me figure out the connections I'm not sure about.
Old 04-08-2011, 09:32 AM
ls1nova71's Avatar
Red Connector
9 DK/GRN FUEL PUMP RELAY CONTROL = not sure
You need this one, it controls the fuel pump relay
You don't need any A/C stuff unless you plan on running A/C and want it controlled by the PCM
Originally went to the EBTCM (anti lock brakes/traction control, not needed
Blue Connector
Old 04-08-2011, 12:27 PM
LSCha0s's Avatar
Originally Posted by ls1nova71
Red Connector
Blue Connector
I do have and will be running A/C and ABS.
I'm not sure what i will be doing. The car has pretty much a stand alone A/C system I have yet to figure it out. I did talk to my old PCM and may be expecting a data signal form it or the BCM.
The ABS from what I have been told just needs a VSS signal.
Thanks for the info. I appreciate it.
Old 04-08-2011, 06:10 PM
datenbrick's Avatar
it will surprise alot of people
Old 04-11-2011, 12:21 PM
LSCha0s's Avatar
I sure hope so ..
Old 04-11-2011, 01:07 PM
-TheBandit-'s Avatar
I like the color accenting on the fuel rails and valvecovers. Should look very nice!
Since you're in the middle of wiring, here's a thread I bookmarked where the builder did a really nice job hiding everything. It's not ideal for troubleshooting, but sure looks clean.
https://ls1tech.com/forums/conversio...g-my-ls44.html
Old 04-11-2011, 06:24 PM
LSCha0s's Avatar
Not bad thanks
Old 04-12-2011, 11:28 PM
90z
90z's Avatar
coming along nicely
Old 04-13-2011, 11:37 AM
LSCha0s's Avatar
Thanks I haven't touched in in two weeks but I have been doing a bunch of research. I need to figure out how to get all my gauges working and keep the Cruise module,A/C control head and Central Control Module happy. otherwise i could loose ABS and A/C.
Old 04-13-2011, 08:57 PM
03Sssnake's Avatar
Build looks great! Let me know if you need any help Rafael.
Old 04-14-2011, 08:36 AM
LSCha0s's Avatar
Thanks
I may take you up on that when it comes time to pull the old one out.
I have it down to the short block but doing it by-myself makes me nervous.
Old 04-14-2011, 11:09 AM
03Sssnake's Avatar
No problem, definitely would not wanna try pulling a motor out of a vette by myself either.
Old 04-16-2011, 05:04 PM
LSCha0s's Avatar
The more I look at it the more I think the F-body accesories are not going to work.
I think I will sell them and get the corvette set up.
As far as I know the only think I can keep is the waterpump.
Are the powersteering and alternator different as well? Also what is the stuff I have now worth? I have verithing but the A/c compressor.
Old 04-16-2011, 07:03 PM
70rsls1's Avatar
Default F-body acessories
If you do sell the f-body accessories I would be interested. I'm doing a 5.3 in a vega and need to get my alternator down a bit. That should be a nice ride the motor looks great!
Old 04-19-2011, 03:53 PM
Agent13's Avatar
Is that Sanden compressor bracket the one from Kwik Perf? I'm getting ready to puchase one myself and was wondering if it looks like it will have any clearance issues? Are you having custom hoses made?
Old 04-19-2011, 04:23 PM
LSCha0s's Avatar
I looks similar but I bought it on fleabay. I will have to have custom hoses made.
I found a site that sells kits that are reasonable. When I get home I will post it up.
Old 04-19-2011, 05:37 PM
LSCha0s's Avatar
It's Nostalgic Air.
They have reasonably priced hose and dryer kits like these.
Quick Reply: LSX In 91 C4 Corvette My Swap
