ls6 t56 to 95 z28 converstion
No speedo signal comes out of the BCM..it goes IN..
Speedo signal comes out of the PCM and gets split from there.. to the Cluster, Cruise Module, Radio(for the volume sensitive ones), BCM..and I havent seen really anything else.
You take the Speedo Signal wire from the PCM and run it directly to the Gauges.
Where are you reading this info at?
