Chevelle (A body) LSX P/S pump to jeep box pressure hose
Kind of a long shot, but I'm putting a 95 jeep steering box in my 72 A body Cutlass with an 05 LM7 5.3 truck motor, P/S pump. The original box felt like an old school bus.
Anyone know a good high pressure power steering hose to use with the correct metric O ring fittings on both ends?
sawzall wielding director
If you are using the truck power steering pump and brackets either the truck hose or a mid 80`s g-body hose will fit. The bends probably won`t be perfect on either, but with a little tweaking of the bends it should fit right in. I liked the fit of the g-body hose better on my el camino and your chevelle probably has similar spacing. The g-body hose is dirt cheap too ~$15 new.
If your pump has one of those variable steering effort valves hanging off the back I would ditch it. I had one and it works fine with it, but there is no point to have it and the truck hose that bolts up to it is $50.
I actually used the truck hose on my swap. With the f-body acc and my standard gear box. I just cut the end off the gear side and flared it. It comes up and around the top of the pulley then does a crazy "s" type thing and loops into the gear box. It's not pretty by any stretch of the imagination but it works.
Go to rockauto.com and you'll be able to look at pics of the different hoses, this way you'll be able to see what will or wont work. Then just go to your local parts store and pick it up.
