got my LQ4 takeout-have questions!!!
got a complete takeout LQ4 and trying to figure out the lay of the land. Have a few questions;
1st - got the 411 pcm and noticed the are no provisions to bolt this down, how do you secure it?
2nd-Can you relocate the pcv valve from the valve cover to the flat plate under the intake- will this work ok?
3rd- I notice a breather fitting from each valve cover- can this be eliminated?
4th-Can I eliminate the solenoid and breather tube that vents to the vapor recovery system?
Thanks, Scott!
Thanks, Scott!
Scott
You can make something to secure it or get one of the stock one (S10 or F-Body) and modify it if needed.
You can switch to a LS6 style PCV which is on the Valley plate.
those should be connected to the PCV valve/Throttle Body. If using the LS6 valley cover. you can plug them.
If your talking the EVAP, Yes.
BC
BC
