Russell quick disconnect fittings
#42
Well at least I'm not the only one with this issue...This happened to me today on the way home from work...Plastic piece stayed on the fuel rail but the aluminum piece popped off...Spewed fuel all over the place luckily not catching on fire because I was at full operating temp and everything was HOT!!! My heart sank when I was cruising and all of a sudden loss of power and a STRONG gas smell instantly...But I popped the alumnium piece back on and tugged on it and it would not budge?!?!?! It got me home but I'm nervous to drive it...
#43
Thanks for posting this. I had a slight concern with my white clips looking abnormal but I didn't know it until someone else said something. I also believe it has to do with the annodize coating they use. I have the black fittings and it looks the same exact way. Since the Corvette regulator won't be seen ill cut rubber hose the length of the regulator body to the an fitting to make sure it doesn't pop off.
It really is a shame that it even had to come to this. A huge company like that should never let customer satisfaction take a backseat like the way they did.
#44
here is a better illustration of the new fittings.
http://www.jegs.com/InstallationInst...799-641300.pdf
#46
Yes, I would like to know more about this... I just got mine not long ago, and want to swap them out for the new versions.
#47
Andy1
#48
I'm also considering just re-doing everything and getting rid of as many specialty/conversion fittings I've used. Should have done nylon/OE type lines from the start, it will be fairly cheap this way.
#49
If I understand this correctly, they have removed any positive retention provision with this new design. It looks as though it's the rubber o-ring that retains the fitting (by friction) to the fuel line. This engineer is less confident with this design, unless I've overlooked/mis-understood something in that link.
Andy1
Andy1
Ditto to the question: Are they going to exchange/recall the old one's? I've got 3 @ $16 each, so that's $48........
Andy1
#52
Andy1
#53
Why not http://www.jegs.com/i/JEGS+Performan...10551/10002/-1use this instead. Then use the typical An fittings. Cheaper than the SS compression fittings
#54
#55
http://russellperformance.com/mc/adapt_fit/fuel.shtml
-8 AN male to 3/8" SAE EFI Female Push on Fitting red/blue (644000)* black (644003)*
* Fits LT1, LT4, and LS1 (pressure side).
8 AN ??? I thought stock hose was 6 AN
And what's with the old pic ?? Can't they update their **** ? It's like only THE MOST IMPORTANT FUEL CONNECTION ! at the block over the headers ! sheesh.
#56
Swagelok makes an excellent product, no doubt about that!
John, have you ever had a failure with a Swagelok tube fitting on a fuel line? I have been told that you shouldn't use compression fittings on fuel lines, however, I know this isn't your typical compression fitting. I have one on my fuel rail, feel pretty good about it, and have not had a problem with it yet. I had a nice discussion with my local distributor (very knowledgeable) and he felt that the application would be fine.
Swagelok insists that you should never use any other brand component with a Swagelok fitting. So if you are going to use a Swagelok fitting, use the whole fitting - don't mix and match the small parts with Parker brand, etc.
Is brass suitable for fuel line use? I used brass on mine but I am thinking about changing it. I heard that the brass will react with the fuel and eventually cause the fuel to gum up.
#57
I just got off the line with Jegs tech. They said the hardline AN adapter (555-110551) fittings are rated to 250psi. Good enough for me to at least try it out
#58
ANOTHER ONE POPPED TODAY!!! WTF?!?!?! It was the fitting at the return line off the vette filter...I didn't realize it this time until the truck puttered to a stop and died...I must've been spewing fuel as I was going down the road cause the tank went bone dry!!! I will be replacing ALL of mine and plan on speaking with Russell/Edelbrock tomorrow!!! I know this IS NOT a user error as I remember testing them for locking upon intial installation...
#59
