Fan control? PCM and Toggle switch...
Old 05-19-2011, 12:31 AM
Dave-1970's Avatar
Default Fan control? PCM and Toggle switch...
So I have an LQ9 in a 70 chevelle. My radiator has two electric cooling fans. I have one fan wired up to be controlled by the PCM (low speed) and was contemplating having the second fan operated by a toggle switch on the dash. Should I just have the PCM control both or is there a good reason to have one fan manualy operated??? Thanks in advance!!
Old 05-19-2011, 03:50 AM
garys 68's Avatar
If you have AC, you might consider having the second fan controlled by the AC trinary switch as well as temp. Otherwise the ecu is ok alone for both.
Old 05-19-2011, 04:30 AM
itsslow98's Avatar
I see no benefit to the switched fan except for being able to turn it on when the car is off.
Old 05-19-2011, 09:20 AM
Agent_Orange_Shuvel's Avatar
If you plan on drag racing it much the toggle switch isn't a bad idea because you can leave the fan on while waiting in the staging lanes. Otherwise running both of them off the PCM works great.
Old 05-22-2011, 03:22 PM
LS88FoxBody's Avatar
I was going to just do switch controlled. But Computer controlled will be nice. Problem is making the normal switch work while switching ground too...
Old 05-23-2011, 05:07 AM
2xLS3's Avatar
Just use another relay with the contacts in parellel of the one controlled by the PCM, then run a switch to one side on the coil and ground the other side
Old 05-23-2011, 09:18 AM
Dave-1970's Avatar
Thanks for the replies!! The car won't see the track too much and I would hate to leave it on and forget about it so I'm going to let the pcm do all the work...
Old 05-25-2011, 11:12 AM
danbo313's Avatar
Some info on how to do both.
http://www.hotrodlane.cc/ONLINETECH/...%20Wiring.html
Quick Reply: Fan control? PCM and Toggle switch...
