5.3 swap fuel pump question
Old 05-24-2011, 09:23 AM
FOSTER21's Avatar
Default 5.3 swap fuel pump question
I plan on swaping a 5.3 in to a 85 k5 blazer and was looking for some info on using an external pump with the corvette filter if anyone could help me out that would be great
Old 05-24-2011, 12:44 PM
FOSTER21's Avatar
Anybody?
Old 05-25-2011, 01:02 AM
welldonecj7's Avatar
what kind of info are you looking for, there are many people that I have read that use an external pump and the corvette filter regulator. From what I have researched it seems like you want to keep the fuel pump lower than the tank to help gravity feed it, as they do not like to pull the fuel, or sump the tank if that is an option. There are a few photos that show how to set this style of fuel system up, I don't have any handy at the moment but I am sure I could find one if that is what you are looking for.
Old 05-25-2011, 08:33 AM
FOSTER21's Avatar
Well there are several fitings on the filter so do u run your return to the filter or to the tank
Old 05-25-2011, 02:21 PM
The return should run from the filter to the tank and then he feed line should run from the tank to filter then from filter to fuel rail.
Quick Reply: 5.3 swap fuel pump question
