What would cause coolant to seep ftom Header bolt??? - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 05-25-2011, 11:32 PM   #1
Default What would cause coolant to seep ftom Header bolt???
I have about 1 hour of run time on my LQ9, and I started to see coolant seeping from only one header bolt. This worries me... Headers are Edelbrock A-body swap headers installed with bolts that came with kit and anti-seize. Does this seepage mean there is a crack in the water jacket and it is spilling into the header bolt hole??? Thanks!!!
Dave-1970 is offline   Reply With Quote
Old 05-26-2011, 12:00 AM   #2
xpndbl3's Avatar
header bolts should not go into coolant passages at all. Make sure the leakage isn't from a higher place on the motor and just seeping around to the header bolts, otherwise you have a cracked head possibly.
xpndbl3 is offline   Reply With Quote
Old 05-26-2011, 12:43 AM   #3
itsslow98's Avatar
which side? on an ls1 you have a port right next to the last header bolt on the back passenger head. If there is no plug in it then it will leak a lot. That could be what you are seeing, or the plug could be leaking.
itsslow98 is offline   Reply With Quote
Old 05-26-2011, 06:16 AM   #4
Take the header bolt out and see if there is a a bigger leak, somebody could have bottomed out a bolt in that hole and crack or broken out the bottom of it. If that's the case put some sealer on the bolt. I've used thwe copper colored permatex silicone when I ran in to this issuse on a non-LS motor with aluminium heads
2xLS3 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Sealant for LS head bolts or are they blind tapped? shaunr Generation IV Internal Engine 2 07-19-2013 11:30 AM
Radiator suggestions Hostile03SVT Cadillac CTS-V 2004-2007 (Gen I) 17 10-15-2012 02:39 PM
Coolant seeping from water pump bolts 69x22 Generation IV External Engine 5 03-13-2011 01:59 PM
Quick head gasket question BCook839 LT1-LT4 Modifications 15 04-15-2010 09:19 AM
New best w/ AI setup.... Barely lol TravisA LT1-LT4 Modifications 11 11-17-2009 11:07 AM
Tags
antifreeze, bolt, bolts, coming, coolant, cracked, engine, gm, head, header, leaking, ls, ls1, motor, motors, passage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
