97 LSx swap
97 LSx swap
alright i know the first thing said will be CLICK THE SEARCH BUTTON...but im not findin what i need. ive been a member on here for years b/c of my 99 SS but recently left because of my stang and other adventures lol.
been thinkin bout sellin the stang till a buddy of mine said.. hey drop a LS1 in it.
well its on now..only problem is NC and its OBDII inspection on 96+ vehicles.
ive seen the swap done with autos on SN95s and T56s which look like a PITA.
so couple questions.
to get a T56 in could i swap a cobra bellhousing with a LS1 bellhousing or are they completely different? because a mustang is a mechanical clutch Vs hydraulic.
and wiring is my nightmare so will this pass the OBDII test(its strictly plug it up and runs parameters minus visual but theres ways around it) and i plan on tuning out the cats, A.I.R. pump etc..
and will i still need the pcm for the stang plugged up to run other features?..ive never swapped anything in these latemodel cars strictly carb'd cars here...
thanks yall.
dont beat me up to bad lol
thanks yall.
Last edited by 97LSxGT; 05-29-2011 at 11:45 PM. Reason: ..misspelled..pretty sure that is to lol
i found quicktime right before i looked lol and i was gonna grab a speartech harness but how is that gonna go as far as the gauge cluster etc? for NC inspection no lights can be on except the SRS lights
yep but maybe the bellhousing from quicktime fixes that?..ill find out the deeper in the build i go..im also gonna give tick a call since there close to the house and i showed my SS with em a couple times...and see what they say since they rebuild em..but i think you may be onto somethin with swappin the input shaft..
LS1Tech Sponsor
Regarding the Check Engine light. Our harness comes with a wire (as I am sure other harnesses do) to hook up to the mustang check engine light. Hook it up and it will function as it should.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
+1 ...please explain..should be the same as mine..and you would still have SES light for no connection to the pcm would prob still pop up..idk for sure tho lol
and thanks jon! im lookin into yall. im still on the edge of my seat with the project..ive found a couple good deals on fbodys..and i can get back my old '80 camaro back for cheap so its all on the air now
