oil pressure sensor adapter
Old 06-09-2011, 12:30 PM
no1kicker's Avatar
Default oil pressure sensor adapter
I am using the stock 91 Firebird oil pressure sensor which is 1/4 npt. I am using two adapters, the first is m16-1.5 to 1/2 npt, then 1/2 npt to 1/4 npt. I could not find a m16-1.5 to 1/4 npt adapter. I did find a 1/8 npt adapter and tried to tap it but the metal was too thin.
Everything fits fine but I am concerned about the m16 adapter. Here is a picture:
The thread length is only 2 or 3 threads, maybe 1/4 inch. It came with an o-ring, but I removed it and used copper rtv. I tightened it down well but am wondering if the oil pressure will back it out without more threads.
Any input would be appreciated.
Old 06-09-2011, 06:29 PM
bczee's Avatar
What I did was that the LS1 oil sender, broke off the black plastic parts. Cleaned it up. drilled and tapped for 1/4npt.. then reinstalled it and put on the aftermarket sender.
Cheap adapter and you know its the right threads for the block.
Old 06-09-2011, 06:38 PM
thenova70ss's Avatar
+1 the same thing i did on the LS1 in my Nova works GREAT.
Old 06-10-2011, 02:34 AM
chuckd71's Avatar
Does the computer not need to see anything from that sensor? Are we talking about the one behind the intake up top?
Old 06-10-2011, 04:46 AM
LS1MCSS's Avatar
It's only for oil pressure. The computer doesn't need to get any signals from it at all.
Old 06-10-2011, 11:46 PM
ls1nova71's Avatar
This is the best no-buck way of getting a fitting, been doing this for a long time, works great!
Old 06-11-2011, 12:11 AM
FastKat's Avatar
Go to any Parker store and they should have that in stock (bushing reducer from 16x1.5 male to 1/4 NPT female)
I was looking for one that was 16x1.5 to 1/8 NPT, and all they had was the 1/4 NPT.
Old 05-01-2012, 09:10 AM
cruisin'73's Avatar
Default Cheap trick!
Tapping the original sensor, I like it! Thanks for the budget idea!
Old 05-01-2012, 12:42 PM
1bad03snake's Avatar
Can i buy an autometer adapter or just screw the autometer sender into the stock sender location? My harness does not have an oil sender connector.
Old 05-01-2012, 01:03 PM
bczee's Avatar
Depends on you Sender. If the theads match up to the Gen III/IV one. Your good, but most of the Aftermarket senders are NPT thread and the Gen III/IV sender is metric (16mm x 1.5mm)
BC
Old 05-01-2012, 01:51 PM
BC
Thank you for the info. Im ordering a florida50 cluster today
Old 05-01-2012, 02:00 PM
LS1PUNK's Avatar
Which ones?
Im wondering if that Autometer bung will work for the oil pressure as well...
*Edit* Nvm.
Auto meter part number #2268.
http://www.autometer.com/cat_accesso...il.aspx?vid=58
Quick Reply: oil pressure sensor adapter
