Hydroboost intake plug part number?
Does anybody know the part number for the plug that goes in the back of the intake on a hydroboost equipped truck (LQ4)? Mine has the nipple for the vacuum brake hose, and I want to delete it. My search turned up nothing. Thanks.
The LS4 guys swaping to the LS1 intake use a 1 31/32" freeze plug:
Next remove the rear vacuum fitting
Take a hacksaw and saw the fitting off and then pry the rest of the fitting out with a flat blade screwdriver,
Here is what you'll end up with
Next plug the hole with a 1 31/32" freeze plug using 3M weatherstripping adhessive or epoxy. Then drill a .441" hole in the lower corner and mount the MAP sensor with a small screw. I used adhessive to seal the screw too.
Very tight fit!
Very tight fit!
Truck intakes are a little different, the plug just pushes in. Thanks anyway though.
