Fuel pressure with Vette FPR/filter?
Old 06-14-2011, 05:00 PM
AHarada's Avatar
Default Fuel pressure with Vette FPR/filter?
I have a fuel pressure sender hooked up to my fuel rail. I am using a Supra pump, Vette FPR/filter, and mostly stock. With key on engine off, I am seeing 58psi fuel pressure, and with engine idling/running I am seeing a constant 68psi. I thought this FPR was supposed to always provide 58psi? It is NAPA part # 3737. What would cause it to perform like this?
Old 06-14-2011, 05:20 PM
bczee's Avatar
might be a bad one... yes, it should be at or around 58psi regulated even with running at idle or WOT.
Take it back and get another one... get a AC or WIX...
Old 06-14-2011, 05:39 PM
devlmaycry's Avatar
I get around 62 with mine, and when it went bad I was seeing around 20psi.
Old 06-15-2011, 06:50 AM
Old Geezer's Avatar
Could be: Pump is running over the regulator...
AT KOEO, there's a 2 second pump on time, and then off.
With the engine running, the pump is producing more flow than the regulator can handle.
Or: insufficient flow capability on the filter/reg return line??
Old 06-15-2011, 09:42 AM
ls1nova71's Avatar
This was going to be my guess too. Also Napa filter #3737 is a Wix filter.
Quick Reply: Fuel pressure with Vette FPR/filter?
