What clutch master seems to work best?
I did a conversion using a LS-2 w/T-56 in my 69' Camaro from a 06' GTO.
I got the clutch master all put in and everything works, but the pedal was extremely hard. Come to find out that the GTO master comes straight on through the firewall and was too far down on the pedal, causing it to be hard. If I try to mount the GTO master on a angle toward the top, it will pull it too far from the pedal and the push arm is not adjustable. So I believe I am going to have to go with a f-body master??? From what car seems to be the best fitting master for this conversion?
Thanks
Thanks
