69 camaro ls6 mount probloms
Old 06-15-2011, 06:24 PM
69ls6's Avatar
Default 69 camaro ls6 mount probloms
bought the $35.00 mounts from ebay that sit engine back one inch.on left side of engine the front side of mount is hitting a mounting tap that won't let plate bolt flush to block.right side is fine.Has anybody had this problom.
Attached Thumbnails 69 camaro ls6 mount probloms-001.jpg   69 camaro ls6 mount probloms-002.jpg   69 camaro ls6 mount probloms-003.jpg
Old 06-15-2011, 06:58 PM
tmcmillan5's Avatar
Yes we have.......grind something off. I think thats just a grounding perch on the block anyway. Take your pick.
Tony
Old 06-15-2011, 07:41 PM
ls68firebird's Avatar
yep, grind the corner on the adapter plate. there is plenty of room around the hole. somebody else i saw had the same problem and ground down the plate.
Old 06-15-2011, 10:21 PM
bczee's Avatar
common problem... +3.. grind and / or cut.. done !
Old 06-15-2011, 10:43 PM
lizeec's Avatar
Tony
That is not a grounding perch, that is your upper bracket mount for the alternator, grind on the ebay plate itself for clearance.
Old 06-17-2011, 09:39 AM
69ls6's Avatar
thanks for the help.grinded plate to fit
Quick Reply: 69 camaro ls6 mount probloms
