66 c10 w/ LQ4 code U0107 problem
Old 06-17-2011, 03:26 PM
BR3W CITY's Avatar
Default 66 c10 w/ LQ4 code U0107 problem
I did my first startup on the new engine today, and although everything ran pretty great, I did run into an issue with this code.
When I go to rev the truck using the DBW pedal, it looses communication. I'm able to rev it ONCE (seems to work fine, and the engine sounds great), but then it loses communication with the pedal and throws this code. I check simple stuff like the fuse but it seems fine. The code U0107 is the only code that comes up. Help is really appreciated! I've been working on this thing for almost 2 years now!
[IMG][/IMG]
Old 06-17-2011, 04:53 PM
lt4malibu's Avatar
what year/model is the harness and ECM from?
Old 06-17-2011, 06:02 PM
BR3W CITY's Avatar
ecm is a green/blue type, tuner said it was an 04 unit.
The harness is a custom build harness from Fuel Injection Connection.
The dbw unit and tac were bought together, but I don't 100% know what year its from.
Old 06-17-2011, 06:33 PM
ls1nova71's Avatar
Definitley sounds like a TAC/ PCM tune incompatibility problem to me. My truck was doing the same thing back when I was changing tunes while trying to get the A/C to work through the PCM. Once I went back to all matching components (PCM, TAC and pedal) it worked the way it should. Whats the part number on your TAC module? And is your pedal the metal type or plastic? 2004 TAc should be a #12573059, and the pedal should be metal.
Old 06-17-2011, 09:31 PM
BR3W CITY's Avatar
i will check the tac # in the morning, and its an all plastic pedal
Old 06-17-2011, 09:46 PM
ls1nova71's Avatar
That's most likley going to be your problem, the plastic pedal is 2006 and newer, so you probably have a 2006 TAC as well. You need a 2003 or 2004 TAC and pedal to work with your 2004 PCM.
Old 06-18-2011, 03:25 PM
BR3W CITY's Avatar
like this?
http://cgi.ebay.com/ebaymotors/03-Ch...item1e6462efb9
Old 06-18-2011, 04:05 PM
ls1nova71's Avatar
Yes, like that, but that one seems kind of high to me.
Old 06-18-2011, 05:11 PM
BR3W CITY's Avatar
i agree, I paid much less for my newer unit. This one happend to be the only one I could find on ebay, and the yards near me don't seem to have any.
Old 06-18-2011, 10:04 PM
ls1nova71's Avatar
So did you buy a pedal and TAC as a pair? I could use a 2006-7 setup provided it's the correct part number if you want to do some trading. I can send you a TAC and pedal, you can try it and make sure it fixes the problem, if it doesn't you can send it back. Just let me know.
Old 06-18-2011, 10:59 PM
BR3W CITY's Avatar
Ya its the matching tac and pedal. I bought them together. I'd def like to work a deal!
Old 05-29-2013, 07:41 PM
billyb22's Avatar
Did you ever get this sorted out? I am having the same problem.
Old 06-03-2018, 11:30 AM
x10
x10's Avatar
So I'm having teh same problem with a variation. I've got a 2005 Avalance engine and transmission in my swap, It works sometimes, We've been driving it since Feb and all the sudden it started.
I have swaped modules with my 2004 pickup and had the same problem, All the P/N match for a 2005 engine, I have ran all the wiring, even ran a new ground and shortened all the 12v lines.
Did anybody post their solution
Quick Reply: 66 c10 w/ LQ4 code U0107 problem
