ls1 in a bmw - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
ls1 in a bmw
Thread Tools Search this Thread
Old 06-18-2011, 02:12 AM   #1
Default ls1 in a bmw
Hi there, so I'm planning on putting an ls1 into my 97 e39. Now I planned on putting a ls with a t56, but am having a hard time finding a good one around here in the Bay Area. Anyone have any tips or advice. I want it to make about 450-500 hp and also I'm on a limited (I want it as cheap as possible) budget it here. Any help would be much obliged.
E39_ls1 is offline   Reply With Quote
Old 06-18-2011, 06:45 PM   #2
rao
rao's Avatar
There are several build threads here and on Bimmerforums.
Good luck!
rao is offline   Reply With Quote
Old 06-19-2011, 01:44 AM   #3
Rao!
I've read on your build, first off I'd like to say you did a GREAT job, and you were one of the people that inspired me to do this (my first build ever).
Now I'm doing this at the shop I work at, I have hoses and all, so I guess that shouldn't be a problem, but I am having issues with the cluster and traction control. What did you do to the canbus to make it work, I want to make this thing smog legal, I also know my cluster is a pre-can which makes it easier.
Do you have traction control on yours?
Also did you ever get that A/c working without the use of the switch?
What parts should I use? camaro radiator, bmw parts, etc?
Any tips?
I know I'm asking a lot here, but as a poor 21 year old trying to do something he never thought he could do, I get all excited lol.
Thank you very much for any help you can offer!
Old 06-19-2011, 04:56 AM   #4
rao
rao's Avatar
1. No traction control
2. AC works, but I do have a separate switch (I have some ideas on how to fix that but haven't done it yet)
3. I am using the BMW radiator with F-body fans and the stock BMW aux fan. The cooling set up works great.
Old 06-19-2011, 05:33 AM   #5
claytonisbob's Avatar
Getting the traction control to work is going to be tough, but who would want it anyway
BMW + LS != Budget
claytonisbob is offline   Reply With Quote
Old 06-19-2011, 04:49 PM   #6
besides the cooling set up, what else are you using?
what are you using for the ac?
are you using the oil filter housing off the bmw?
how did you make up for cutting the gto pan?
Also, do you think the cruise control will work still? mine was originally a 6 speed
I'm 21 with a lead foot...I figured traction control might at least help me out a bit lol
Old 06-19-2011, 04:58 PM   #7
Cal gm sports salvage in rancho Cordova/ Sacramento area. That's where I've been going for the past 10 years for all of my gm needs.
anton28 is offline   Reply With Quote
Old 06-19-2011, 07:14 PM   #8
gnx7's Avatar
www.norcal-lsx.com There is a $1200 LS1 on there.... not complete though.
I would like to own an e39 LSx setup myself one day
gnx7 is offline   Reply With Quote
Old 06-19-2011, 08:53 PM   #9
I just tried to call the guy...turns out he lost his phone...again lol. I'm definitely calling GM sports tomorrow. Maybe I can get a better price if I buy it through my shop
Old 06-20-2011, 12:51 AM   #10
hey guys whats up!!! yes i saw the E39 build also!! it was awesome! i am in the same boat. i am also low 20 something yr old and i am inspired to do an LSx swap into my car hahaha. also it needs to be cheap as possible.
i also figured that i'll put a 5.3L in there (as long as its 350hp and up, and it fits, i dont care) with a T56 trans. will a 5.7L or even a 6.2L fit? i can get the 5.7L cheaper than the 5.3
my car: 2003 BMW 330xi 5 speed manual with (another) blown engine.
should i make my own thread or can i tag along in here? hahaha.
i'm thinking of buying a used engine, but many of them in my area have high miles, like 100k-200k and some even more! how are these engines at that mileage? currently my engine has around 143k and its damn tired... unfortunately. many other E46's have over 200k and are fine
mujjuman is offline   Reply With Quote
Old 06-20-2011, 11:55 PM   #11
How does it have another blown engine? Also 100k or so is nothing, mine is way over that. only reason I'm changing engines is because the exhaust valves are bad. What did you do to the car?
Old 06-21-2011, 12:43 AM   #12
I want to change engines because my intake valve stem seals are bad. they leak tons of oil into the combustion chamber. also my CCV valve is shot (relatively easy fix). we are also assuming my piston rings might be worn as well. the engine needs a typical rebuild.
the head gasket is fine though, it doesnt burn coolant nor is there mixing of coolant and oil. thank God.
I drive it normally. i dont abuse it, and i'm very particular about maint. keeping reasonable rpms when cold, etc. I feel like the used engine i bought was pretty worn out before I installed it.
also, i'm finding 6.0's for even cheaper than 5.7s and lower miles... if a 6 liter can fit in my 3 series engine bay, it would be awesome!
Old 06-21-2011, 02:38 AM   #13
I can't find anything here, been looking with no luck so far
Old 06-21-2011, 02:06 PM   #14
i searched for all over the US... i figure its like $200-$300 to ship from California to NY.
Old 06-21-2011, 05:12 PM   #15
millersta's Avatar
any lsx should fit they are all basically the same motor although most 6.0 and 5.3's are iron blocks which are heavier
millersta is offline   Reply With Quote
Old 06-22-2011, 09:08 AM   #16
hey guys im doing this swap on a e39 528i sport and was wondering about 2 things motor mounts and how do i line up the engine and tranny with the rear end so my drive shaft will be strait
BMW REAPER is offline   Reply With Quote
Old 06-22-2011, 01:35 PM   #17
Quote:
Really? That's awesome! So does that mean a 6.2l might fit as well?! (feeling a bit ambitious now...)
Old 06-22-2011, 01:36 PM   #18
Quote:
check out rao's thread. so much good info there.
Old 06-22-2011, 05:29 PM   #19
About 2 months ago I talked with a ref about a different swap. BTW, do NOT talk with CARB or BAR officials. I got more counter intuitive wrong information from the BAR guy than I could count. Call and speak with a ref. But here is what I gleaned about of that discussion:
For CA, he can't do any of the truck engines. He has to swap a car engine into a car. There is no wiggle room there. But what I was told is an iron block could be used with all the stock LS1/6 parts. But personally, I see that becoming a hassle to try to prove a 5.7L vs 5.3L/etc.
I have not seen a LSx BMW swap that was made CA smog legal yet(I've looked a few times here and bimmerworld)
The huge issue is the exhaust from what I've seen. CA doesn't allow custom headers and as far as I know, nobody has made a CARB compliant LSx BMW header. I'm not sure if a stock manifold or existing CARB compliant LSx header would work for the BMW.
Tuning also becomes an issue. My understanding is they do check for readiness on some of the codes. If they are tuned out, no smog. VATS would not be an issue.
Fuel related stuff also becomes an issue. Tank venting and monitoring equip from the donor vehicle must be installed.
To the OP, keep in mind you do need to use a 97 or later donor vehicle.
BTW, having done an almost successful engine swap in CA about 15 years ago with a TBI engine(had an idle issue I couldn't solve), the more sanitary and accessible everything is, the more happy the ref will be. Aside from the idle issue, I was in and out of the ref within 15 minutes.
Lil'John is offline   Reply With Quote
Old 06-30-2011, 03:42 AM   #20
what is a "ref"? the smog guy in california?
Related Topics
Thread Thread Starter Forum Replies Last Post
BMW e39 oil pan Rubans Conversions & Hybrids 2 04-11-2016 05:23 PM
ls1 twin turbo and a/c ??? farmstar Forced Induction 8 01-13-2014 09:25 PM
LS1 vs. M62 in BMW E38/E39 michal5000 Conversions & Hybrids 7 03-25-2011 10:12 PM
E39 M5 vs LS1 SSmokin99 Dyno Guesses & Bench Racing Forum 8 03-13-2010 09:46 PM
have a few boost questions. 383lt1impala Forced Induction 3 07-13-2009 06:56 PM
Tags
1998, 540i, bmw, california, e39, e46, good, kit, ls, ls1, ls2, mileage, smog, speed, thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
