Do Edelbrock motor mounts put the Transmission in the stock location
Old 06-19-2011, 12:57 PM
Bobby G's Avatar
Default Do Edelbrock motor mounts put the Transmission in the stock location
I am looking to by a g force crossmember for my 1980 Trans am and I was wondering if the edelbrock motor mounts that I have will put the trans mission in the stock location. My trans is a 4l80e so I dont want to buy a $300 crossmember and still drill holes. Does anyone here have this set up
Old 06-19-2011, 01:37 PM
SIKHS 5's Avatar
im not sure --- why not buy a full kit? im going to order a BRP A-body conversion kit soon.
Old 06-19-2011, 10:29 PM
bczee's Avatar
Yes, if they are the 1" Set back plates. They would move the engine flange back to where the stock TH350/TH400 bellhousing Flange would meet the engine.
Old 06-20-2011, 04:36 PM
Bobby G's Avatar
They are Part #6701
Old 06-20-2011, 06:58 PM
bczee's Avatar
Yeah, 1" setback's. As you view an picture of the plates, the Bottom bolt hole is about 1" forward of the lower / front mounting boss location of the engine.
I use them as a template for my plates that I made from 1/2" alum plates.
Old 06-20-2011, 10:28 PM
Project GatTagO's Avatar
Received 1,388 Likes on 877 Posts
Yes, they do.
Andrew
Quick Reply: Do Edelbrock motor mounts put the Transmission in the stock location
