ls3 or ls1 crate engine
Old 06-29-2011, 05:40 PM
jpac716's Avatar
Cool ls3 or ls1 crate engine
I can get an ls376/480 or ls1 crate engine for the same price after all the add-ons but I am not used to a lot of power in a vehicle so my question is should I go for the ls1 or ls376/480. It is to put into a a gutted 94 camaro ss for a daily driver.
Old 06-29-2011, 05:58 PM
ponjohn's Avatar
Get the LS3 and if you concerned about the power have a tuner ( or yourself) just dial it back. Reduce the timing and soon you want full power....
Old 06-29-2011, 06:11 PM
oakley6575's Avatar
LS3.. It has 10 years or so of minor tweaks that make it a better motor all the way around.
Old 06-29-2011, 06:21 PM
BLINGOLE's Avatar
theres not one reason you should buy a ls1 if the ls3 is the same price.
Old 06-29-2011, 06:36 PM
bczee's Avatar
My general rule is go for the Best, Latest and Biggest. but if your willing to settle for less. (for what every reason). then that answer your question.
But for a DD.. an LS1 will do you OK... it all depends on what your requirements are..
Old 06-29-2011, 06:39 PM
jpac716's Avatar
Cool Any one else
Do you guys know anyone who has put an ls3 in an f-body
Old 06-29-2011, 06:46 PM
TransWS6Am's Avatar
I think I might know a few people who have.
I put a 416ci LS3 stroker into my 2001 T/A
Here is a link that may have some information for you, your swap is going to be more work with your Camaro being a 94.
https://ls1tech.com/forums/generatio...02-f-body.html
Do you plan on a LS3 computer/harness, or an 99-02 F-body computer/harness? Yes I know I left the 98 f-body computer out, it's for good reason.
Old 06-29-2011, 07:18 PM
jpac716's Avatar
Cool Computer
I am not totally sure I have only been into the auto game for about a year so I was looking for suggestions. So which one do you thing would work or be better for a daily driver application.
Old 06-29-2011, 07:45 PM
jpac716's Avatar
I forgot to mention there is no bcm, pcm, or transmission so the car is ready for anything that will fit
Old 06-29-2011, 07:48 PM
Brdlvr's Avatar
As stated above many times. If you are really getting them for the same price then get the ls3!! More cubes and like Oakley said, it's been tweaked for perfection.
Old 06-29-2011, 08:30 PM
TransWS6Am's Avatar
Eh... an LS3 harness is probably going to be the easiest, it would pretty much be plug and play with no tuning required. The main problem is going to be getting your gauges to work.
Old 06-29-2011, 08:57 PM
jpac716's Avatar
I was thinking about getting a racepak iq3
Old 06-30-2011, 01:26 AM
jpac716's Avatar
I have one more question can I install a ram air system onto the ls3
Old 06-30-2011, 11:03 AM
jmilz28's Avatar
bam - truth! Avoid the LPE conversion module at all costs.
Old 06-30-2011, 11:40 AM
TransWS6Am's Avatar
+1, do not get a lingenfelter conversion box!
Old 06-30-2011, 11:41 AM
TransWS6Am's Avatar
of course, why couldn't you?
Quick Reply: ls3 or ls1 crate engine
