97 LT1 M6 to 99+ LS1 A4
Old 07-02-2011, 11:19 PM
jlaudioholic's Avatar
Default 97 LT1 M6 to 99+ LS1 A4
I've read many useful posts on this particular swap. Have a few questions to those that have done this. Has anyone successfully kept the LT1 k-member with motor mount adapter plates? I know the_merv tried and it moved everything back 3/4". Everyone says just get a ls1 k, but I just can't find a reasonably priced one right now. I've already acquired the Ls1 steering rack and shaft.
I will be going the corvette filter/regulator route. Do the stock Lt1 lines plug directly into this filter? What do I do with the vent line?
Can anyone show me a pic of their modified a4 crossmember mount? Maybe a little more info on how you made it work?
Any help would be appreciated. I'm still in the researching and parts gathering stage and have yet to buy the motor/tranny yet, but it will most likely be 99+.
John
Old 07-03-2011, 08:41 PM
flame's Avatar
Check the link in my sig for details
Old 07-03-2011, 08:42 PM
oChristiano's Avatar
I'm about to start a '96 to 01 swap, I'll be taking pics of everything. I'm going to be doing it bar legal though.
Old 07-04-2011, 11:56 AM
the_merv's Avatar
I moved everything back cause that was the only adapter plates out at the time..now they have ones that move the engine all over the place. There is a set that is specifically for this swap, I've seen them.
Here is a pic with the standard plates on the block..
If you find the ones for this swap they will work a hell of alot better than these did for me.
Old 07-04-2011, 02:24 PM
RGSS's Avatar
I used a BMR LS1 K member with my LT1 4L60E and the transmission was moved 1/2" to the front. I kept the LT1 tranny crossmember.
So, either way you decide to do it its a matter of elongating the slot in the transmission crossmember. No big deal at all.
Old 07-04-2011, 02:35 PM
RGSS's Avatar
I located the Corvette filter/regulator in the LT1 filter location. The supply line from the pump plugs directly into the filter. The return line has to be modified slightly, but can be doneusing the same connectors from the LT1 lines and a small piece of FI hose. Supply line to the engine was made using the 3/8 metal section and AN6 braided lines.
The vent line remained in the same location and was connected to a cannister purge solenoid located on the Intke manifold.
Old 07-07-2011, 11:06 PM
Thanks for the replies. Went through flames thread alot good info in there.
Another question, I found a good deal on a 98 Ls1 pullout. How much different would the wiring be? I see that most have used 99+ harnesses and I understand that there is little difference in the 99-02 harnesses. Has anyone taken on the 98 harness?
Old 07-08-2011, 11:45 AM
flame's Avatar
The 98 harness is actually easier to use but the 98 pcm is less desirable for tuning so its up to you. This is a good source for wiring info http://www.lt1swap.com/98-02_ls1.htm
Old 08-16-2011, 08:54 AM
Picked up a complete '01 motor today. Just need tranny. 2 questions though. Where can I find that tool used to repin wires? Also would a walboro/racetronix fuel pump setup get me where I need to be on fuel psi?
Old 08-16-2011, 10:14 AM
RGSS's Avatar
The Racetronix Walbro pump will suffice.
I use a very small Craftsman screwdriver to release the terminals from the connectors.
For the PCM you dont need any special tools.
Old 10-03-2011, 03:00 PM
I've almost got everything I need for the swap. I picked up a complete 4l60e from a 99 T/A for a little of nothing, however it needs a rebuild. In the meantime to get me going would it be possible to use a 4l60e from a 98 gmc pick up? I I
Old 10-03-2011, 03:26 PM
It was behind a gen 1 sbc and does have a removable bellhousing.
Old 10-03-2011, 09:47 PM
the_merv's Avatar
Yup, it'll work.
Old 02-12-2012, 10:46 AM
update: Dropped the motor in Friday. The LT1 transmission crossmember however needs to be modified. There's no way slotting it will work for me, so I will be welding a plate or tab of some sort on the front of the trans crossmember and then slotting that. I will post pics as soon as I get it done. I also tried using the crossmember that came with the '01 transmission I bought , but the bolt locations are completely different on the Lt1 car for sure!
I Still have not decided which air intake setup Im going to use yet. Will I need any kind of special elbow if I use a LT1 style aftermarket cai? Also what did you guys use to plug the unused 5/8 nipple on the LT1 radiator?
Old 02-12-2012, 11:30 AM
RGSS's Avatar
My LT1 CAI (including LT1 elbow) was used in my conversion without any modifications:
For the unused nipple on the radiator I used a small section of 5/8 hose and plugged it with a machined aluminum cap on the other end.
Old 02-12-2012, 12:16 PM
the_merv's Avatar
Plug the Radiator like mentioned..the LT1 type 4L60E and the newer LS1 type 4L60e have the mounts in different locations on the case..that is the only real non-direct bolt in part of the swap with the LT Chassis when installing an Auto. The T56 is the same for both.
Old 02-15-2012, 11:32 AM
Ok a quick wiring question. On my '01 engine wiring harness I had moved 220c pink ignition wire to 220e. The wire I removed from from 220e was a black/white stripe. What do I do with this wire? From the schematics that I've read its a ground wire circuit 451, and it seems to end up at
the DLC. Should I ground this anywhere, or just disregard it?
Old 02-15-2012, 04:56 PM
the_merv's Avatar
That is a ground in the Engine Harness. It grounds in the Harness, I would take the car-side of that wire and ground it to the chassis.
Old 02-26-2012, 10:15 PM
Default Crossmember
Here are pictures of my crossmember modification I made to mount a 98+ style 4L60E into a 93-97 Body using a LT1 crossmember. First pic shows it primed. Second is painted and installed.
Old 02-26-2012, 10:41 PM
ok I tried to start engine today and no start. The engine turns over but no fire. Ithink Im not getting fuel. I noticed that when I turn the key forward the fuel pump does not prime. When I repinned my harness I moved the green/white fuel pump relay C101 D to C220 J,and C230 Grey wire fuel pump ground to C210 B. What do I do with C210 D which is a fuel pump prime connector? I cannot find where to connect it to the LS1 harness. Also my PCM was reprogrammed and VATS was removed.
Quick Reply: 97 LT1 M6 to 99+ LS1 A4
