lq9 flywheel bolts and spacer
Old 07-10-2011, 01:48 AM
zeeshan's Avatar
Default lq9 flywheel bolts and spacer
are the manual flywheel bolts the same as the flex plate bolts? is there a spacer behind the flexplate that needs to be changed to
a manual spacer? are the torque specs for the flexplate bolts the same as the flywheel bolts?
thanks!
Old 07-11-2011, 04:19 PM
zeeshan's Avatar
bump to top!
Old 07-11-2011, 04:48 PM
garys 68's Avatar
I bought manual trans flywheel bolts from the dealer. If you're bolting an LS1 flywheel to an LQ9, no spacer needed.
Old 07-11-2011, 10:12 PM
zeeshan's Avatar
thank you!
the lq9 manual wasn't too clear about this for some reason
Old 07-12-2011, 06:35 AM
garys 68's Avatar
The LQ9 was never offered with a manual trans as far as I know.
Get bolts for a LQ4 6.0 or LM7 5.3 manual flywheel.
Quick Reply: lq9 flywheel bolts and spacer
