5.3 T56 4th gen....whos got one?
The only thing you would really have to do is drill & tap for the Alternator Bolt, everything else will be a direct fit & plug-in..depending on what 5.3l Engine it is..GEN III will go right in, just need to drill & tap still.
If you want to get technical you will have to change out the front Coil Springs for the LT1 spec ones if it's an Ironblock.
Just the cam. im putting one inot my 95 bird converted the lt1 m6 to an LS m6 Im swapping the LM7 with LS6 cam intake, Cam, and longtubes should be running in the next couple of weeks.
I've done the swap, but my car was orig. an LS so it was literally bolt on stuff aside from drilling and tapping a hole for the Alt. To swap it into an LT car you'd need a wiring harness, k member, new fuel lines or get alum rails and put inlet on one side and return on the other along with a new input shaft, slave and bell housing. I'm not sure if the Master Cylinder is the same as a LS car.
Super chevy did a build up on a 5.3 not long ago, its called Modern Mouse I believe. With just heads, cam and intake it put down some really good numbers IMO.
If your just doing a small cam then I'd just do rod bolts, valve springs and new pushrods, maybe new lifters and lifter trays while your in there just for the hell of it.
5.3's are the same as the LS1, the only thing like it was said above is that you'll have to drill and tap for the alternator bracket.
Here's a 5.3 I Installed in a customer's car although it was an LS1 car to begin with...
http://youtu.be/TNZMsgRq8Os
