5.3L into 86 C1500
5.3L into 86 C1500
I have a 2002 Chevrolet Tahoe with a 5.3L that I will be using for a donor vehicle for my 1986 Chevrolet pickup, first off I want to make sure I get everything I will need from the donor vehicle I've removed the radiator, ECM, under hood fuse/power distribution box, fuel tank, I know I have to get the gas peddle anything else?
Feul lines you will have to switch to a hardline or high pressure feul line. Drive shaft can more than likely stay unchanged unless you mount the motor back really far.
Removing wiring removed the fuse box/power distribution box I know I need the harness white the black plug(engine harness) the warness with the green plug appears to be for the lights shouldn't need that, what about the harnesses with the red plug and the one white the white plug?
Will I need to get my computer reflashed? still looking for an to the following
For example most ppl use this mount Trans-Dapt Performance Products 4595 - Trans-Dapt Performance Engine Swap Motor Mounts which sets the engine back 1" but most ppl running this mount also run an older style transmission, I plan to run the 4L60 and not sure if I require that set back
