NAPA green brake lines
Old 07-23-2011, 08:52 AM
Jimbo1367's Avatar
Default NAPA green brake lines
Has anyone tried using the easy to bend NAPA green brake lines as fuel lines? Also.......... do they resist corrosion fairly well?
thanks,
Jim
Old 07-23-2011, 09:56 AM
Jimbo1367's Avatar
16 views and no one used these lines for fuel?
Old 07-23-2011, 10:16 AM
ls1nova71's Avatar
The lines I get at Orielly's are coated green, but I haven't noticed them being any easier to bend than the old silver lines. Are they just a Napa part?Personally I liked the old lines better, for looks anyway.
Old 07-23-2011, 11:24 AM
boostnut's Avatar
https://ls1tech.com/forums/conversio...e-options.html
See post 7. I'm not sure if post 4 refers to the same "green" line or not. From what I understand the green tint is just a coating that is supposed to prevent corrosion. Its easy to bend & flare, I'd give it a shot.
Old 07-23-2011, 01:45 PM
Hodge's Avatar
thanks,
Jim
Easy to bend lines? Who fed u that story? The old uncoated lines and the "green" lines are all mild steel lines. I have never noticed any difference in bending or double flaring them.
Old 07-23-2011, 03:56 PM
tfi racing's Avatar
I have used the coated lines for fuel,return and brakes on a project,and yes,they do seem easier to work with.As for rust,I can't tell you,not an issue with cars that are stored indoors around here.
Old 07-24-2011, 07:02 AM
FastKat's Avatar
I have always bought the green-coated brake lines at Advance. I think the brand is American Grease Stick. I have used them for fuel (3/8" OD) and they work fine.
They're also relatively easy to bend as long as you have a decent tubing bender.
Old 01-25-2014, 03:20 PM
TipsyMcStagger's Avatar
How about NiCopp brake line sold at Advance? Any feedback on working with it?
Tipsy
Old 01-26-2014, 02:12 PM
i r teh noobz's Avatar
Nicopp is decent, but I suggest the version that SURR makes. Its thicker and easier to bend without kinks. Both are very easy to cut and flare.
Old 01-26-2014, 03:25 PM
Pop N Wood's Avatar
Tipsy
I used nickle copper line for both brakes and fuel. The stuff is a dream to work with. The stuff I got was expensive. At the time I got it the cheapest place to find it was England.
That link looks like a good price. Looks like they sell 3/8 and 1/2 inch line which would work for fuel and they have it cheaper than Jegs. Believe me, that stuff is massively easier to work with than just about anything else, and it is suppose to last forever.
Old 01-26-2014, 04:17 PM
If this is the stuff If this is the stuff
, it's nearly half the price of NiCopp.
Tipsy
Quick Reply: NAPA green brake lines
