g-body swap info needed
Old 08-07-2011, 10:43 PM
64supersport's Avatar
Default g-body swap info needed
my next project car is a 87 regal 5.0v8 with a auto trans. I am wanting to do a complete 5.3 of 6.0 budget swap. what would be the best way to go with it, carb or efi and if there is anyone that has done this swap would greatly appreciate any input.
Old 08-07-2011, 11:00 PM
LS1MCSS's Avatar
You shoud try the search button. There are probably two dozen g-body swap threads.
Old 08-08-2011, 02:37 AM
the_merv's Avatar
Where?
Old 08-08-2011, 04:45 AM
GNCLONE's Avatar
I just finished my 87 Regal swap, was not bad at all.
Do a lot of reading: this site, and Maliburacing.com, and Gbodyforum.com.
If you want specifics, PM me
Old 08-08-2011, 06:47 AM
Old Geezer's Avatar
www.turbobuick.com
Old 08-08-2011, 02:56 PM
any other sites for info, which motor mounts/ oil pan to use ?
Old 08-08-2011, 03:02 PM
74novacustom's Avatar
check out mervs build
Old 08-08-2011, 11:30 PM
sawzall wielding director
G-Body's Avatar
Mounts and pan depend on personal preference. Seems a bunch of people use the adapter plates and a hummer or CTSv pan which clear but hang under the crossmember. I used a f-body pan which requires setting the motor further back and notching the heater box, but does not hang below the crossmember.
Start by checking out John B`s swap http://www.montecarloss.com/ls1montecarloss/index.html
Old 08-09-2011, 12:00 AM
the_merv's Avatar
I used the Hummer Pan..it does hang down about 1.5"...got an armadillo with it the other day..
Old 08-10-2011, 08:08 PM
where is that?
Old 08-10-2011, 08:18 PM
the_merv's Avatar
Originally Posted by 64supersport
where is that?
Parked in my garage.
I'm just messin..lol.. here is the link..
https://ls1tech.com/forums/conversio...-carlo-ss.html
Old 08-12-2011, 11:46 PM
how about you park it over at mine
Old 08-13-2011, 12:51 AM
the_merv's Avatar
Send some monies my way..lots of it..
Old 08-13-2011, 01:37 PM
labelblack68's Avatar
i would do carb if i did it again, easier to setup the fuel system and cheaper
Old 08-18-2011, 02:55 PM
yea that seems to be the best way for my application. I dont realy want to tie a whole lot of $ up into this one. already done that with my 64 chevelle.
Quick Reply: g-body swap info needed
