Starter /crank rpm question for hi compression 408
Old 08-08-2011, 11:02 AM
crossbreed383's Avatar
Default Starter /crank rpm question for hi compression 408
Hey all
i have a 14-5comp 408 i just started for the 1st time last saturday
this thing seems to crank slow even though it has a new fully battery(900cca)
and same 00 battery cable that was in the car with my last race engine(old school 383sbc)
all i changed was going to a ls engine along with going from a aftermartket tci sbc starter to trying the oem ls starter
im wondering if the stock starter might be the issue
its out of a 06 yukon w a 5.3 i think?
im wondering if an aftermarket starter is better than the factory starter in terms of cranking rpm
if so is anyone using any specific piece, and if so, do you have any cranking rpm data
thanks
Old 08-08-2011, 11:50 AM
cutlass_455's Avatar
I think LS9 starters are beefier, if you wanna go the OE route.
Old 08-08-2011, 08:51 PM
S10xGN's Avatar
Originally Posted by crossbreed383
Hey all
thanks
FYI: You shouldn't crosspost in different subforums, it's too confusing. Just post once and then use threads to link to that post...
Old 08-10-2011, 07:10 AM
GA95DCMSS's Avatar
With compression like that, I definitely think you need a beefier starter. I have a doc around here somewhere with some info in it, i just gotta find it.
Quick Reply: Starter /crank rpm question for hi compression 408
