93 LX Mustang 4cyl to LQ4 swap questions
Old 08-08-2011, 04:05 PM
softballnrd27's Avatar
Default 93 LX Mustang 4cyl to LQ4 swap questions
I just purchased a 93 LX Coupe with a 4cyl with the intentions of swapping in the 6.0 I have in my garage. I will use a th400 trans and a 9" rear(I already have).
Here is what i plan to buy/use for the conversion:
UPR Tubular K-Member kit for mod motor(coil over kit, a-arms and brace)
UPR lower and upper rear Control Arms
UPR Subframe connectors
UPR rear springs
5 lug swap in the front
What do i need to ditch on the 4cyl besides the motor/trans/rear?
I was reading on stangnet.com that you have to use all the 5.0 suspension pieces and some say you don't.
Anyone have a complete 4cyl to LS swap thread here? Parts list?
What about the stock gauges, can they work with the LS Swap?
I need some help on this so I can get it done right.
Old 08-08-2011, 06:28 PM
ponjohn's Avatar
Carb or EFI?
Old 08-08-2011, 08:08 PM
EFI for sure
Old 08-08-2011, 08:31 PM
single digit dreamer
parish8's Avatar
we put a 5.3 in an older 4cyl fairmont.
stock k member, stock brakes(manual and 4lug), stock springs. car handled ok and stopped ok too. many stops at the track from 135+.
Old 08-08-2011, 10:07 PM
itsslow98's Avatar
I have a half a build thread I never finished just search my name. Mine was a 93 4cyl that already had an 8.8 swapped in it. I went with AJE kmember and motor mounts and the trans crossmember and it think it fit great.
You can use the stock mustang cluster but its a pain in the *** and not worth the trouble converting mechanial to electrical and stuff. I also swapped in a 99 trans am gauge cluster and the volts, coolant temp, speedo and tach all work. Just the gas gauge and oil pressure dont.
Old 08-08-2011, 10:33 PM
bigchief52780's Avatar
just tap the 6.0 sending units spots to ford sending units sizes. you can use the 4cyl stuff. i did a 6.0 in a 89 using all stock stuff. kmember, trans cross member, rear end, suspension, and gauges. when u get to that stuff i ca help you in your way.
Old 08-08-2011, 10:44 PM
itsslow98's Avatar
I thought the tach in the foxes were known to be extremely unreliable past 5k?
Old 08-09-2011, 06:44 AM
parish8's Avatar
who cares if it is an auto?
Old 08-09-2011, 10:48 AM
ponjohn's Avatar
If an F-body cluster was used why did the OP gauge not work?
Old 08-09-2011, 10:52 AM
Itsslow98-How do you like the AJE parts?
Is there a way to mount Autometer gauges in the area where the stock gauges are? I can't look at it just yet and alot of my questions will probably be answered when I get home and can physically see the car.
If anyone has pictures they can email me of the swap that would be awesome. I can't get to any picture hosting sites out here. softballnrd27@gmail.com
Quick Reply: 93 LX Mustang 4cyl to LQ4 swap questions
