Project Emmy Lives!!! 1968 Bel Air Wagon L92/6L80E
Old 08-08-2011, 05:57 PM
BelAir1000's Avatar
Default Project Emmy Lives!!! 1968 Bel Air Wagon L92/6L80E
Here's my build thread.
https://ls1tech.com/forums/conversio...r-wagon-3.html
Got her running today. After fighting it all weekend. After a "write entire" with the hp tuners she's running. I don't think the VATS delete took the first time.
Video....
http://www.youtube.com/watch?v=IecUBsFw_xY
Now I have the issue of not seeing much oil pressure.
It started off as none, engine rattling a little, then she quieted down.
The pressure sensor still seems to be flaky. Then after sometime I started seeing a little more....but only about 10psi at 2000, 25+ at 3000ish, 35ish at 4k(just spiked the rpm).
When i installed the musclecar oil pan, I lubed the oring, fed it on by hand to fully seat it, then put the bolt in. I was extremely careful not to damage the oring. Could I still have screwed it up? Also read about an oil pump pressure relief valve sticking on these engines. Gotta do some more reading. And finally, I am planning on starting with a new oil sending unit. Its not been working for who know when the engine was pulled from the '07 'lade. Maybe inactivity made it take a puke. Thoughts?
Old 08-08-2011, 06:24 PM
ponjohn's Avatar
What oil filter?
Old 08-08-2011, 06:41 PM
BelAir1000's Avatar
Fram Extragaurd PH10060
Old 08-08-2011, 07:09 PM
ponjohn's Avatar
Heard many stories of Frams taking out fresh motors.
Never happened to me but I always ran a NAPA which is made by wix.
Old 08-08-2011, 07:25 PM
BelAir1000's Avatar
I just looked up what Summit calls for for the musclecar oil pan...they call for a AC delco PF46. That cross refs to a Fram PH3506. But for the H3 Alpha and Escalade, the PH10060 is called for. Might be onto something.
Old 08-08-2011, 09:09 PM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
I wouldn't run a Fram filter on my lawn mover...
Andrew
Old 08-08-2011, 09:13 PM
BelAir1000's Avatar
FYi...
Changed to the AC Delco PF48. PF48 has the relief valve. PF46 same size, no valve.
No change to oil pressure.
I started wiggling the sensor a little and the pressure went from 0 to as high as 75.
I ordered a pressure sensor and it will be here tomorrow. Crossing my fingers.
Old 08-08-2011, 09:14 PM
Hopefully its just a bad sensor. Crossing my fingers for you....
Andrew
Old 08-09-2011, 07:40 AM
gofastwclass's Avatar
That wasn't a fluke, you need to do a write entire for the VATS to take.
I'm sure you have a bad sensor. One of the yards I get engines from seems to damage 8 of 10.
Old 08-09-2011, 04:53 PM
BelAir1000's Avatar
Sensor changed...50psi at cool idle. Thank Goodness.
Old 08-11-2011, 09:52 PM
1961ba427's Avatar
Nice wagon. I'm glad to see you got your oil pressure worries worked out.
You wouldn't happen to know where a 61 wagon tailgate is would you?? (Nomad/Impala, Parkwood/BelAir, Brookwood/Biscayne)
I've been looking for 2 years with no luck. It's really the only thing holding up me having a 9 passenger wagon for an every day driver for me & my 4 kids plus my fiance & her 3 kids. LOL
Old 08-28-2011, 11:06 AM
RollinSlow84's Avatar
Default Mounts?
Thats a sweet wagon! I have my eyes on a 68 Biscayne coupe that's hopefully going to get a 6.0.
What did you do for the transmission and engine mounts? What did you do for the driveshaft?
Old 05-04-2012, 06:36 AM
BelAir1000's Avatar
Hey I know this is super delayed but I hope you get it and it helps with your project.
I used the 6L80E out of the Escalade that came with my 6.2.
My wagon has two mounting locations for the stock transmission cross member(4-sp/Small block and then big block maybe?). I used the rear most location and made a steel plate with slotted holes to adapt the stock member to the 6L80E. Basically the plate extends the reach of the stock cross members mount brkt. I then used the stock mount that was in good condition from the TH400.
For the driveshaft, I was able to use the larger 1350 yoke from the escalade and adapt it to the stock Bel Air driveshaft using a 1350/1310 conversion u-joint. I also recently upgrade the stock 1310 rear u joint as well.
For engine mounts I think I used energy suspension mounts. I will say this and maybe other people have had issues as well. But I found the mount fit to be a little tight to the block. Ended up having to file a few holes or make them slightly larger with a drill bit. Initially the adapt plate was pulled so tight against the bolts it was rolling threads. I fixed the plate, replace the bolts, and was good to go.
Let me know if you have any other questions. I'll send you a pm with this info as well.
Old 05-24-2012, 07:30 PM
68wagon's Avatar
so would you recommend going with a different engine mount? i'm fixing to going down this same road with the same car... so basically anything you've had to do, i'll have to do... lol
Quick Reply: Project Emmy Lives!!! 1968 Bel Air Wagon L92/6L80E
