LQ9 Cast Iron Block with H3 Pan which dipstick
Old 08-09-2011, 03:04 PM
john59's Avatar
Default LQ9 Cast Iron Block with H3 Pan which dipstick
Hi Guys,
Getting conflicting info. on this, need a dipstick and tube for my swap, which one works with the Cast Iron block, I know the 5.3 Aluminum has a further recess in the block so obviosly different tube and stick as opposed to what I need, what are you guys using
Thanks
John
Old 08-09-2011, 04:01 PM
74novacustom's Avatar
IVe got LQ9 Iron Block, using the H3 pan.
Using stock H3 Dipstick and tube.
I think i still have the part tag on the dipstick, if i do i will post the part number tonight.
Old 08-09-2011, 04:56 PM
john59's Avatar
Ok thanks, and it reads correctly, looked at a 5.3 and the block recess for the stick is different from the 6.0 block just wondering.
Old 08-09-2011, 07:35 PM
ItDoRun's Avatar
What about an LY6 motor and an F-Body pan?
Old 08-09-2011, 07:43 PM
Well i guess i took the tag off.
Call Midway Chevrolet in Phoenix, parts department, there is a parts guy there named Mike, he has a 6.0 Turbo Shortbed Silverado, he is an LS and conversion master. He is the one that got me all my parts.
Old 08-10-2011, 02:19 AM
garys 68's Avatar
Thanks for the info. I put a corvette pan/tube/dipstick on an LQ9 and it barelt read anything on the dipstick. Always wondered what the difference was.
Thanks
John
Old 08-10-2011, 02:36 AM
john59's Avatar
Thanks I'll give him a call and see what he says.
Old 08-10-2011, 09:45 AM
lamdenali's Avatar
Is the H3 pan the same as the CTS-V pan ?
Old 08-10-2011, 12:43 PM
pdsq98gt's Avatar
No they are different.
Old 08-10-2011, 01:30 PM
LS1MCSS's Avatar
Thr dip stick needs to match the pan in order to read right. If you call the guys at SDPC they can probably fix you up.
Old 08-11-2011, 02:14 AM
the_merv's Avatar
Did you order the H3 Pan Kit from GM?
Old 08-11-2011, 04:48 PM
john59's Avatar
Yes ordered my pan from GM $ 107.01, also just had my 8.8 axles and rotors redrilled for chevy bolt pattern, have C6 wheels going on this S10 should be perfect width with no adapters.
Old 08-11-2011, 08:44 PM
the_merv's Avatar
I have the kit and it came with the Tube & Stick..no issues here.
Quick Reply: LQ9 Cast Iron Block with H3 Pan which dipstick
