DIY Cold air intake
Old 01-30-2012, 11:55 AM
SamHatco's Avatar
The MAF is inserted at the end of the tube. With a 4" tube the fit was perfect if not a little snug. Spectre make a bracket that supports the end of the tube MAF and the filter. I purposely mounted it so you couldn't see it. It is bolted to the inner fender under the tube. Bitch to get at but makes the install clean
Sam
Old 01-31-2012, 12:22 PM
2Aspire's Avatar
Sam
Very nice.. Where does the wire run? Does it follow the tube underneath? It is so clean, at least form this angle that I cant even see the MAF wires.
Old 02-02-2012, 12:05 AM
Jesus Freak's Avatar
Hey SamHatco, where'd you get the coil covers? I'm looking for some that don't say corvette on them.
Old 02-02-2012, 12:39 AM
Track_FC's Avatar
Cool thread. Thanks!
Old 02-02-2012, 07:22 PM
SamHatco's Avatar
The wire for the MAF is underneath the tube.
Old 02-02-2012, 07:23 PM
SamHatco's Avatar
They are corvette covers I just filled in the lettering and sanded smooth the 5.7 numbers.
Sam
Old 02-04-2012, 08:37 PM
gMAG's Avatar
The pieces were ordered from Speed Inc. I cut the tubes to size, painted the clamps, cut off the excess metal from the clamps, and fabbed a support.
The CAI needs support. I used one of those steel frames that you would find in a file drawer. The steel frame was cut, then bent in a vise to obtain its' shape. A couple of rivets hold it in place. The design helped to center the filter for best air intake.
Old 02-04-2012, 09:10 PM
V8Rumble's Avatar
Thumbs up
Well HOLY CRAP!! For starting with a "generic plastic build-your-own" pipe set, that just looks "RETARDEDLY" good!! Think I might just have to look at that, thanks for the tip!!!
Old 02-05-2012, 12:29 AM
no1kicker's Avatar
I made a 4" with parts from intakehoses also, total was about 100 including the K&N.
The following users liked this post:
rob_mcarthur (10-10-2019)
Old 02-05-2012, 09:34 AM
Jimbo1367's Avatar
SamHatCo
Do you have any type of support/hanger on the CAI? Looks killer. I was orgianlly thinking of this setup, but I am starting to concider aluminum tubing too. Any thoughts of the alum? I would imagine the plastic wouldn't soakup heat even better than aluminum.
Old 02-05-2012, 10:14 AM
MynameisLee's Avatar
There are some great ideas in here. I'll be needing one of these here soon
Old 02-05-2012, 12:00 PM
  #32
FatfreeGTO's Avatar
I used that same kit to build your own. Haven't gone as crazy as Sams though his does look awesome!
Old 02-06-2012, 09:06 PM
  #33
SamHatco's Avatar
SamHatCo
I used a t-bolt clamp bracket from Spectre. Look in their accessories section of their catalog. The plastic tubing I used is easier for me to work with compared to aluminum. It doesn't transfer as much engine heat as aluminum would and since I was looking for a seamless one piece look and I can't weld aluminum the AirRaid kit was the right choice for me. Hope this helps
Sam
Old 02-10-2012, 07:08 PM
  #34
rallystyle's Avatar
what size kit are you using? i have a stock ls1 TB and have been looking for what is the right size to go with.
Old 02-11-2012, 03:03 PM
  #35
Jimbo1367's Avatar
Sam
Thanks for the input.
Old 05-02-2013, 12:33 AM
  #36
-TheBandit-'s Avatar
btt because the more ideas the better.
Old 05-02-2013, 12:55 AM
  #37
01cherryreds10's Avatar
God I looked back at the first page and saw what mine used to look like
I may try and rout the filter down with a 90° bend through the wheel house to drop the IAT some
Old 05-02-2013, 02:51 AM
  #38
roninsonic's Avatar
Some of these intakes are sexy...
I've always just bought cheap tubing and connectors from autozone and stuck a nicer filter on the in... Tube is tubes, as far as I'm concerned
Old 02-18-2016, 01:45 PM
  #39
2Aspire's Avatar
Default Resurrected from obscurity but for a purpose
First off, as you can see from my posting in this thread, I had seen what SamHatco had done with the AirRaid kit.
However, that was only after I had already pieced together my first Cold Air Intake from the net for my LS2 swap.
Now that I have pulled the LS2 and in place am putting in, essentially, an Eforce LS9, I wanted to revisit this subject.
So for this round, When selecting a DIY Cold Air Intake solution, I set out to achieve the following objectives:
1. That it would be durable yet lightweight.
2. That it would not conduct or transfer Engine compartment heat.
3. That it would look seamless and not pieced together.
So With advice, and a great example here from SamHatco , I decided to explore the AirRaid U-build-it Air intake system.
Honestly, I will say that the only item I was skeptical about was how durable the bonded cut tube would be, as He had used Crazy glue to bond the pieces together.
For this reason, I purchased the following kit and decided to put it to the test.
Amazon.com: Airaid 100-400 UBI (U-Build-It) Intake Kit: Automotive Amazon.com: Airaid 100-400 UBI (U-Build-It) Intake Kit: Automotive
Below is a short video that demonstrates the durability of the bond with a simple drop test.
https://www.youtube.com/watch?v=eMdZ...ature=youtu.be
Please keep in mind that it was not only After this test, but also several more drops and several hand held stress pulls not in this video, that I decided that it was indeed suitable to adhere this material.
I will post more here after I assemble my kit and finish.
A big (and Very late) thanks to SamHatco for sharing.
Old 02-18-2016, 07:54 PM
  #40
jimmyg's Avatar
I glued mine together and 4500 miles later it's still mint. Loctite is the best super glue to use. Gorilla super glue the worst lol.
Quick Reply: DIY Cold air intake
